LED conversion question
Discussion in 'XJ Technical Chat' started by Jake750, Sep 28, 2020.
Tags:
  1. Jake750
    Jake750 Member
    Detroit
    1986 yx600 radian. Should I be wary of installing LED turn signals, headlight, and possibly tail light?
    I converted all the lights on my girlfriends honda rebel to LEDs and it caused a wholeeee mess of problems. I had to install load resistors and buy a modern rectifier/regulator.
    Is it known that LEDs cause problems on these bikes? And if so, what are there precautions or mods that will allow for a safe transition to LEDs?
    Thanks fellas. And hope all is well in this 2020 madness.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    should'nt be any problem converting any of the running lights to led.
    the problems arise when you want to convert the turn signals, you have to replace the flasher relay ,to an electronic one, thereby loosing the self canceling feature.
    otherwise ,as you say , you have to go down the load resistor route, or make up your own relay, there's a "how to" on here somewhere.
    stu
  3. k-moe
  4. bigfitz52
    I still haven't seen an aftermarket LED turn signal that is as visible in bright sunlight as an incandescent one. I mean, they must exist; but I've never seen any.
