LED conversion Question!!!!
Discussion in 'XJ Modifications' started by Derson59, Feb 16, 2016.
  1. Derson59
    Derson59 New Member
    Bloomington,MN
    there are a few threads on led conversion in the mods and diy forumsff of the charging system
    some involve load resistors to make the system work some do not
    there is also a thread about led headlights
    good way to take stress of of the charging system don't forget to do your running lights and plate light
    How to convert to LED's and still have everything work
    DIY LED/Digital Fuel gauge
    new link for led fuel guage
    http://www.mez.co.uk/ms13-new.html
    speedo, turn signals, and idle
    this one has link to led head light
    HID Headlight
    New Turn Signals - Seca 750
    and if you do not have a manual yet free download
    XJ750 manuals
  3. Derson59
    Derson59 New Member
    Bloomington,MN
    I did take a look at those I didn't see anything mentioned, but I just bit the bullet and ordered one, so I will try it out(hard wire) and post on it.
  4. XJ550H
    basicly as long as you do not want the auto canceler to work its all good
    I was board figured i would put all the links together in one post
    there are some led flashers that have an adjustment knob to keep the flash rate
  5. Derson59
    Derson59 New Member
    Bloomington,MN
    I was looking at their site and they have a device for that as well.
  6. k-moe
    I used that relay on my scooter (Zuma 125). One thing to note is that the OEM connector it comes with is not the same as the OEM connector that was in use in 1982, so it's not a direct fit for your XJ.
    Now, before you go spending money on nes turn signals, what have you done to ENSURE that you have ALL of the undone maintenance caught up on?
    Working tun signals won't keep you from having to walk home.
  7. Derson59
    Derson59 New Member
    Bloomington,MN
    From what I saw I was expecting that I would have to hard wire that connector up. So far what I have done was clean out the carbs, redone the front brakes(new master sylinder), compression check the engine, new oil and filter. Did a rough hook up of the headlight and instrument cluster. And that's the things I have done but there is more that I have to do. Bacisally I got a bike with a crate of parts. So it will end up being a complete over haul on the entire bike.
