Little explotions on 4th carb...
Discussion in 'XJ Technical Chat' started by Rod1, Aug 21, 2021.
  1. Rod1
    Rod1 Member
    San Luis, Argentina
    I have little explotions in the 4th carb and also the 4th cil stop working probably due to a fauled sparkplug. My question is can a broken diafram could be the cause of the explotions?
    Also leaking gas from that 4th carb...
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    You need to remove the carbs and find out what's going on inside. It may be as simple as getting the float at the proper height and/or replacing a needle valve. Have you checked the pilot screw setting? A torn diaphragm could also cause a problem, but that would be the last thing I would expect.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    It's weak. When in the load/rpm range is important, as this could pin down the issue?
  4. Rod1
    Rod1 Member
    San Luis, Argentina
    Diafram is broken. Trying to get the replacement (here, Argentina, is noy easy) where I can find the measures of the diafram in case I can fit another from other bike...
  5. tabaka45
    Brunswick, Georgia
    Some folks have repaired them and maybe they will chime in. Other than that you can try Chacal or EBay.
    Rod1 likes this.
  6. Rod1
    Rod1 Member
    San Luis, Argentina
    Ebay dont send them fo here...
  7. k-moe
    Get a condom, and some rubber cement. Clean the diphragm, cut the condom to make a patch, and glue it on to the diaphragm. It's just like patching a tire.
    chacal likes this.
  8. chacal
    We can!
    Rod1 and Timbox like this.
  9. Rod1
    Rod1 Member
    San Luis, Argentina
    Sent you an email.
