Little rubber blocks
Discussion in 'XJ Technical Chat' started by Timekeeper, Dec 18, 2012.
  1. Timekeeper
    Timekeeper New Member
    Today when I started my bike a little rubber block (about 5mm x 5mm x 7mm) fell on the ground, I found there are a few wedged in between the cooling fins of the engine block. I am guessing these are for damping vibration? Not sure, are they necessary, what are they for? There are a few on both sides of the engine, hope you can see them in the pic.
    Thanks,
    Timekeeper
    1985 XJ700 Maxim
  2. maximike
    maximike Member
    Portland, OR, USA
    Yep, damping vibration is correct. I've heard the engine can "sing" pretty loudly at highway speeds without them.
  3. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I read that they reduce a weird noise that occurs at certain RPM's. I have not run any of my XJ's without them so I can't say what will happen.
  4. bigfitz52
    Not just at highway speeds. Without them there are a few "resonance ranges" RPM-wise, that the motor will go through; you can actually pick up on the "singing" more easily riding around town.
    Try it sometime; you won't hurt anything but you'll put the rubber blocks back.
  5. ryanrules
    ryanrules Member
    Philadelphia, PA
    I've replaced these on some 2 strokes (with much taller fins) with some short cuts of vacuum hose
  6. Timekeeper
    Great, thanks all for the feedback. Next question is, how many are there supposed to be? I have no idea how many may have fallen out before I got the bike.
  7. paul.hardy
    paul.hardy Member
    Tasmaina - Australia
    I have blown a few out with a pressure washer and lost them I have not noticed any dofference, but I suffer from a bit of industial deafness.
  8. bigfitz52
    Which bike? It varies by model/displacement.
  9. osprey1000
    osprey1000 Member
    Annapolis, MD
    Fitz, back to the Original Post, it is an '85 700 max.
  10. bigfitz52
    Oh, sorry; missed that.
    According to the fiche, there are (8) of one size (probably the larger ones) and (14) another size (probably the smaller ones) used on the aircooled XJ700.
  11. RickCoMatic
    Those Rubber Dampers are alleged to dampen a Harmonic Frequency that is said to be a cause of fatigue while riding.
    I believe it's true.
  12. pnthubb
    pnthubb Member
    San Diego
    I have never even noticed those things before. I'm making it a point to look at mine when I get home...
  13. Bjarvis
    Bjarvis Member
    Victoria BC Canada
    Anyone know if they should be located in specific locations on each side of the engine ? I would assume so, but how to determine this .... Say for a 1980 for example.
  14. RickCoMatic
    You can position them to be even or in a pattern.
    The idea is to keep the Cooling Vanes from vibrating.
    3/8th Inch sections of High-temp Vacuum Hose wedged between the Cooling Vanes will do the trick.
  15. pnthubb
    pnthubb Member
    San Diego
    Yep! Eight on each side.
    Man, how do you get that engine so clean? Mine has that nasty old aluminum look to it all over.
  16. pnthubb
    pnthubb Member
    San Diego
  17. Timekeeper
    pnthubb, I believe this bike has been kept in a garage most of it's life, I have done some cleaning with simple green. I think the engine is painted silver, and the camera flash enhances the brightness of its appearance. You can see in the pic the spark plug has some corrosion but the bike was really clean when I got it. New plugs soon.
