Little trouble....
Discussion in 'XJ Technical Chat' started by xdarrickx, May 13, 2008.
  1. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    So I rode the bike to work yesterday. On the way there and on the way back it stalled and wouldn't restart until after a couple minutes. Then rode fine after wards. Both times were when coming to a stop and just stalled like I turned the fuel off. Any suggestions?
  2. Torgunde
    Torgunde Member
    Toms River, NJ
    Did you recently clean your carbs or anything? If your float bowl levels are too high, it would cause the engine to flood and stall out as the excess fuel would slosh around at stops.
  3. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    I did just clean them. How do I adjust the float bowls.
  4. xyxj650
    xyxj650 Member
    Fergus Falls MN
    here is a pic you can use this to reference where they need to be set.
    Using this method will get you close then you have to put the bowls on and check them with fuel in them. That can be done by putting a peice of clear plastic tubing on the drain hole on the bowl and opening the drain. Fuel will run in there and you just hold the tubing up and it will show you where your level is at.
  5. xyxj650
    xyxj650 Member
    Fergus Falls MN
