loaner shim tool?
Discussion in 'Eastern US and Canada' started by fonz, Mar 19, 2008.
  1. fonz
    fonz Member
    Philly burbs
    just wondering if anyone in the Philadelphia area had a shim tool they wouldnt mind loaning out for a weekend some time in the not too distant future. not sure when im gonna end up doing the job but id like to do it soon. figured id try borrowing one first before buying since i probably won't need to use it again for a long time. if not, it will be included in the next order from chacal.
  2. phillyturbo
    phillyturbo Member
    Philadelphia PA
    i have 1 i could loan ya where r u located im in philly near the NE airport
  3. fonz
    fonz Member
    Philly burbs
    Thanks. Im near the International airport right off 95. Ill send you a PM when I think i might get around to checking the valves.
  4. Timetonut
    Timetonut Member
    Philadelphia, PA
    I'm right between you two, and I don't have the shim tool. If you need someone in the middle to do a pass off run, I could help. :)
  5. phillyturbo
    phillyturbo Member
    Philadelphia PA
    Thinking about going out on sun the 6th for a ride maybe penns landing.or somethin like that
