locating the air filter....
Discussion in 'XJ Technical Chat' started by tonymyrs, Jan 13, 2007.
  1. tonymyrs
    tonymyrs Member
    portland, Or
    I know this sounds a little dumb but I havent recived my manual yet so how can I locate the air filter box so I can check it?
  2. bosozoku
    bosozoku Member
    Albany, Oregon
    It's under the fuse box, below the seat. There are 3 phillips head screws holding the cover in place.
    It's easier to deal with if you remove the fuse assembly from the airbox lid first.
  3. Timski
    Timski Member
    Morganton, NC
    If it's like the Maxim, remove the seat and the box is directly under the forward part of the seat. Remove the screws/bolts that secure the airbox lid to the box. On the Maxim this cover has 4 fuses on it, but the fuses are often re located as the bikes age since they are a frequent source of trouble. I suspect the setup in the Seca is very similar to the Max.
    Tim
