looking for a new master cylinder for 1980 xj650g
Discussion in 'XJ Technical Chat' started by Jzap99, May 25, 2008.
  1. Jzap99
    Jzap99 Member
    Mississippi
    do the ones from mikes or partnsmore work good and fit right?
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Those should work just fine. Is there something wrong with your that renders it unrebuildable? A master cylinder is not hard to rebuild. Can be done is a couple of hours. Hardest thing is bleeding the system which you will have to do with a new cylinder also. The rebuild kit is only $24 from partsnmore.
  3. Jzap99
    Jzap99 Member
    Mississippi
    no nothing wrong i just figured after you spend the 30.00 on the rebuild kit and then the 10.00 on the sight glass and gasket, I wish they had made extra sight glass replacement parts rather than having to take a piece of glass and glue it in, and on top of all that powdercoat or gunkote it would almost be cheaper to buy new for 67.00
