Wanted Looking for a Upper Fork Tube for 83 XJ750 Maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by Cant Register, Feb 25, 2016.
  1. Cant Register
    Cant Register Member
    washington
    I'm looking for a good, cheap fork tube for a 1983 XJ750 Maxim. For shipping, I just need the top part. Not sure what years and size bikes fit.
    Thank you,
    Chris.
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    The part numbers are different, but if an XJ650 Maxim one will work for some reason then I have one you can have for the cost of shipping.
  3. Cant Register
    washington
    What year 650?
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    1982
  5. Cant Register
    washington
    So far, I was able to find they are the same circumference. The fork seal number is the same for both forks. Could be shorter or a be different inside. I'll keep trying to figure it out. Thank you,
    Chris.
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Let me know if you need any measurements.
  7. Cant Register
    washington
    Can't beleave I haven't got any more leads or fork tubes. If you still have them, can you take the weight off, measure from the top of the tube, to the place it goes into the bottom fork. Then from top of the tube to all the way to the bottom. Can you do that?
    Thank you,
    Chris.
  8. jayrodoh
    jayrodoh YimYam
    Cleveland
    Heres what I've got. 36mm diameter, tapers to 33mm at the end. Length is approx 26-1/4". Inside diameter is 30mm at the top and 22mm at the tapered end.
    Tapered end pics:
  9. jayrodoh
    jayrodoh YimYam
    Cleveland
    Overall shape is good, no pitting and straight. I needed to replace one and it was cheaper to buy a set of used forks so I have one extra.
  10. Cant Register
    washington
    I found out it is not the same. Thank you for the offer. In my post, I described it as "the top part." It's actually the "inside" part.
    Wouldn't you know it. The guy at the Yamaha shop said the 83' XJ750 is the only year, model with those forks. He could hardly use the machine that looks up parts, didn't understand what he was looking at, so I'm hoping he was wrong on that part.
    Thank you,
    Chris.
  11. XJ550H
    83 will fit maxim or midnight maxim part number 6 26 correct?
  12. XJ550H
    all of the XJ750 (except the XJ750-X and the XJ750RL) are 36mm,
    you could possibly use another year front end
    this link says 82 and 83 tube are the same click part number
    . Tube, Outer 1
    15R-23126-00-00
  13. Cant Register
    washington
    Yes. The only thing Yamaha says fits is the 1982 or 1983 XJ750 Maxim. I could get another "front end" but I was hoping to only have to buy the one fork tube, since that's whats wrong.
    Thanks for the replies,
    Chris.
  14. Busted Knuckles
    Busted Knuckles Member
    North
    82 XJ650R Seca compatible? I have the complete fork setup ready to go.
  15. Cant Register
    washington
    Still looking for an 1982-1983 XJ750, Upper Fork Tube.
    Chris.
  16. Busted Knuckles
    North
    Got mine on my Seca 650.
  17. MiGhost
    MiGhost Well-Known Member
    He is correct! 83 only. Air valve screws into top of the tube. Not the slide on side cap like the rest of the 750's.
    The 650 fork tubes are approx 1" shorter than the 750's
    You can use other fork tubes but you would need to replace both.
    ~Ghost
  18. hogfiddles
    Correct
  19. Cant Register
    washington
    The local shop in my town said 1982 or 1983 xj750 Maxim will fit.
  20. hogfiddles
    Well..... You could also check with Len.......
    BUT----- PERSONALLY, I would take the word of these people here over the word of any shop any day.
  21. Cant Register
    washington
    Thank you for the reply. I PERSONALLY would go by the Yamaha part number, at the shop, over most of these people.
  22. MiGhost
    Maybe the guy that has 3 of them might know?
  23. hogfiddles
    I 've been away a few days.... Just got home. i"ll do a side-by-side comparo later today
  24. Polock
    What's wrong with the one you're replacing
  25. hogfiddles
    Um, looking back through the forum, I found this ......so exactly what part DO you need?
  26. Cant Register
    washington
    One fork tube is slightly bent. It throws the whole bike off when turning. Anything other then a 1982 0r 83 750 Maxim is different inside. I could replace both forks with different ones, but since I only needed a tube, that's what I was looking for.
    Chris.
  27. hogfiddles
    Ok, now for the fly in the ointment--
    Not showing pics yet....here's why
    Compared forks:
    '83'650 Maxim fork
    750rj Seca fork - same length
    '83 750 Maxim fork- SHORTER than the 650 Maxim fork
    Gotta look at these more.
    Len?!?!?!
  28. chacal
    Huh..........I show the 750 Seca to be almost 3/4" longer, plus it uses a slide bushing on the lower section. I show the 750 Maxim and 650 Maxim to have the same overall length.
    HCP8525
    Aftermarket chrome forks INNER TUBE
    replaces oem #4H7-23110-00-00
    LH or RH
    36mm OD
    non-threaded inner bore (for cap bolt)
    26-1/4" long
    does not use a lower bushing
    1980-83 XJ650 Maxim
    HCP8531
    replaces oem #15R-23110-00-00
    LH or RH
    36mm internally threaded for cap bolt, , threads start 12.8mm below top of tube
    26-1/4" long
    has air bleed hole and air joint retaining ring groove
    1982 XJ750 Maxim
    HCP8532
    replaces oem #22R-23110-00-00
    LH or RH
    36mm internally threaded for cap bolt, threads start 18.7mm below top of tube
    26-1/4" long
    no air bleed hole or retaining ring groove
    1983 XJ750 Maxim
    HCP8533
    OEM chrome forks INNER TUBE
    replaces oem #5G2-23110-00-00
    LH or RH
    36mm non-threaded internally for cap bolt
    26-7/8" long
    uses HCP8481 or HCP10704 lower bushing
    1981-83 XJ750 Seca
  29. MiGhost
    All my reerences show the 650 fork tube at 580 mm and the 750 fork tube at 608 mm.
    deffinately could se some verification here.
    To clear up the confusionon of the difference betweem the 82 and 83 forks.
    The 82 750 Maxim uses the single air inlet with cross over hose and slide on caps for the air assist. This puts the air hole on the side of the fork.
    The 83 750 Maxim uses seperate air inlets for each fork. No extra air hole on the side.
    ~Ghost
  30. chacal
    Ghost, where are you finding those numbers at?
  31. MiGhost
    I am going to have to dig a bit. It has been a few years since I did the virago 700 wheels.
    This will be my project for the night. Will get it to you asap.
    ~Ghost
  32. MiGhost
    It had to be the Tarozzi TNK fork tubes I was researching but I am not finding the 700 virago.
    And I may have assumed The 750 Maxim used that same length fork as the 750 Seca.
    Here is what a quick search turned up
    Yamaha XJ 900 1983
    http://www.fastfromthepast.com/05-0143
    http://racetech.com/TNKProductSearch/YAMAHA/XJ 900/1983
    OEM PART NUMBER 31A-23110-30
    DIAMETER 37
    LENGTH 583
    Yamaha XJ 650 1980 to 1982
    http://www.fastfromthepast.com/05-0071
    http://racetech.com/TNKProductSearch/YAMAHA/XJ 650/1980-1982
    OEM PART NUMBER 4K0-23110-00
    DIAMETER 36
    LENGTH 608
    Yamaha XJ 750 SECA 1982
    http://www.fastfromthepast.com/05-0101
    http://racetech.com/TNKProductSearch/YAMAHA/XJ 750 Seca/1982
    OEM PART NUMBER 5N1-23110-00
    DIAMETER 36
    LENGTH 685
    Yamaha XJ550RJ Seca in North America
    http://www.fastfromthepast.com/05-0045
    http://racetech.com/TNKProductSearch/YAMAHA/XJ 550/1981-1983
    OEM PART NUMBER 5F8-23110-00
    DIAMETER 35
    LENGTH 585
    Yamaha XS 1100 S 1980 to 1982 ( 82 XJ1100?)
    http://www.fastfromthepast.com/05-0077
    OEM PART NUMBER 5K7-23110-00
    DIAMETER 37
    LENGTH 690
    http://racetech.com/TNKVehicleSearch
    http://www.tnk.it/pdf/Catalogo-Catalogue.pdf
    http://motorcycle-parts.com.au/files/appcharts/3_PPMP_Tarozzi_Standard_Fork_Tubes_2016.pdf
    Will work on it more later.
    ~Ghost
  33. MiGhost
