Wanted Looking for piston rings for XJ700
Discussion in 'For Sale, Trade/Swap, Wanted' started by Elijah Vertsehovski, Jul 30, 2021.
Tags:
  1. Elijah Vertsehovski
    Elijah Vertsehovski New Member
    South Carolina
    Well, seems like I'm not alone in this journey. I got 1985 XJ700 with blown piston rings. If anyone has any in hood condition or maybe even new ones please let me know. Or maybe you know someone who makes custom rings, that will work too.
    Engine wasn't running for two years. And last time it was running it smoked. So when I tried to start it carbs were messed up so I'm waiting for parts to rebuild them. But about engine, I checked the compression and it was below 80psi. Added a bit of transmission fluid and it picked up compression up to 110-120. And thats in all cylinders.
    Any ideas or advices?
  2. Franz
    Check the valve clearances first before you change piston rings, then do another compression check.
  3. Elijah Vertsehovski
    South Carolina
    Ok, will do. Bc this motorcycle has only 16xxx.
  4. Franz
    Piston rings should be fine at that low mileage. Probably needing some ATF and acetone mix down the spark plug holes for a few days to free the rings up due to the bike not being used. I would definately check the valve clearances first. They have to be adjusted correctly before any carburettor work is done. Do you have a Haynes Manual for your bike?
  5. Elijah Vertsehovski
    South Carolina
    I have manual that I bought online. Its a pdf file with scans from old book. And it doesn't have a first page lol so I dont know if it's Haynes or not. Carbs are leaking like crazy, that's why I'm rebuilding them.
  6. Franz
    The main reason I referred to the valve clearances is so that you can syncronise your carburettors once you rebuild them, and to see if the compression figures increase further in the meantime. Most of the time the engine does not need dismantling, and in your case with such a low mileage and similar compression between cylinders that is a good sign.
  7. Elijah Vertsehovski
    South Carolina
    Thats kinda what I thought. I looked up symptoms and it fits the picture. At least as if for now I know what to do. Will be back after I get those few things done :)
  8. Franz
    The valves go deeper into the valve seats on low mileage engines. Shim changes are not needed as much on higher mileage engines although they should still be checked at 8000 mile intervals according to my Haynes manual. Check the easy things first.
    Elijah Vertsehovski likes this.
  9. hogfiddles
    With only about 15k on it, it’s really only at about time for the first clearance check.... it’s not gonna be that far out of spec yet. Not saying some won’t be, but they’re not going to be in critical condition yet. Ive seen plenty where they’re about 35k and haven’t been checked—— That’s bad.
    I would be trying to use fluids through the plug holes first, to try and get things loosened and freed up.
    Just because it blew smoke doesn’t necessarily mean you need a set of piston rings. There’s other reasons an engine will blow smoke.
    if the engine is already being opened, then yeah, do shins while you’re already in there.
    Dfox
  10. hogfiddles
    It’s recommended that airheads get checked about every 5k mi (+\-, imho), and liquid cooled’s about every 15k.......
  11. Elijah Vertsehovski
    South Carolina
    Well gentlemen.. here is the results of valve clearance check:
    1 cylinder
    Exhaust 005. out of spec
    Intake 006
    2 cylinder
    Exhaust 007. out of spec
    Intake 005
    3 cylinder
    Exhaust 006. out of spec
    Intake 006
    4 cylinder
    Intake 0025. out of spec
  12. hogfiddles
    Metric...... in mm please
  13. Elijah Vertsehovski
    South Carolina
    1 cylinder
    Exh 0.13mm
    Intake 0.15mm
    2 cylinder
    Exh 0.18mm
    Intake 0.13mm
    3 cylinder
    Exh 0.15mm
    Intake 0.15mm
    4 cylinder
    Exh 0.15mm
    Intake 0.06mm
  14. hogfiddles
    Ok, now pull each out, 1 at a time —
    Flip it over, record the number stamped on it, then put it back. Give us the numbers, and we’ll help you get the right sizes for shim swap.
  15. Elijah Vertsehovski
    South Carolina
    Cylinder 1
    Exhaus shim Y276
    Cylinder 2
    Exhaus shim Y275
    Cylinder 3
    Exhaus shim Y265
    Cylinder 4
    Exhaus shim Y265
    Intake shim Y270
  16. hogfiddles
    I’ll crunch numbers this evening for you, unless someone else feels like beating me to it.
    I’d recommend you pull the in-spec shins to get those sizes, as well. That way, next time you have to do it, you have ALL of them recorded already. Your job will take less than half as long .
  17. Franz
    Are the clearances the same on all XJ engines? I assume they are?
  18. hogfiddles
    Air heads, yes...Liquidcooleds have different numbers
  19. Franz
    Okay l don't have the shim chart.
  20. Elijah Vertsehovski
    South Carolina
    I have a shim chart from original Yamaha manual for XJ700
  21. Elijah Vertsehovski
    South Carolina
    But even here i don't see the numbers i need.
  22. hogfiddles
    Not the correct chart
  23. Elijah Vertsehovski
    South Carolina
    Do you have a right chart?
  24. hogfiddles
    Here’s the chart:
    I got in later than I expected. I’ll run numbers in the morning.
    BTW, exhaust 1 is a typo.... you meant 275 right?
  25. Elijah Vertsehovski
    South Carolina
    Good question. It actually looked like 276. I can double check tomorrow.
  26. Toyobaru866
    Toyobaru866 Active Member
    Netherlands
    The manual for the 700x says 26.600 miles but I think the 15k that you mentioned is a wiser choice...
  27. hogfiddles
    I Believe the ‘accepted’ time is the 25k approximation is for the first check.... then every 15k after that, even though the 26.6k is from yamaha.
    26.6 is a loonnggg time between checks, imho
  28. Toyobaru866
    Netherlands
    +1
  29. Elijah Vertsehovski
    South Carolina
    Cylinder 1 270
  30. Elijah Vertsehovski
    South Carolina
    So by the looks of it I need 2x 260 and 2x 265.. does anyone has any, or knows anyone who has shims?
  31. hogfiddles
    Elijah.....I’m working on your numbers right now......question on cyl 2:
    you said 2 exhaust is out of spec, and gave numbers, but if it is the intake that is out of spec unless you wrote something else wrong. Can you correct #2 both E and I for me
    current— awaiting cyl 2 double-check:
    Dfox
  32. Elijah Vertsehovski
    South Carolina
    I made mistake when I wrote that its out of spec. Numbers are correct.
  33. hogfiddles
    I’ll look to see if I have any 260’s
    updated pic:
