Loose steering
Discussion in 'XJ Technical Chat' started by ktp1598, Sep 6, 2011.
  1. ktp1598
    ktp1598 Member
    Mount Washington
    My XJ550J has a wierd problem. I recently replaced my factory ball bearing setup with an All Balls tapered set. Properly torqued and retorqued, the front still "knocks" as if the bearings aren't seated. A call to all balls reassured that I have the correct bearings and they are in the right places. The kit came with 2 grease seals that were also used. The races are seated correctly. Did I miss a trick or something?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Hopefully the bearings or races were not dammaged durring the installation. A small hammer nick on the race will cause problems. Could your "knock" be from the wheel bearings?
  3. ktp1598
    ktp1598 Member
    Mount Washington
    I don't think so, they've already been checked. I'm having a friend who used to be part owner of a motorcycle shop do this work for me. He's basically checking out and fine tuning everything since I put it together. I've kept him busy! :oops: The races (I installed them) were fine and were seated correctly. Are all that's needed are the upper and lower bearings and the grease seals? I'm concerned I may have left something out like a washer or something. I installed everything that came with the kit and followed advice given here for the installation.
  4. PTSenterprises
    PTSenterprises Member
    I got a taper bearing kit from Chacal and installation was straight forward and simple. There is a toque spec you need to follow though, which is difficult if you dont have the proper tool for the special nuts.
    make sure you arent feeling a clunk in the front axle or forks transferring up into the steering head. Thats about all I got for suggestions.
