Loss of power situation identified and corrected
Discussion in 'XJ Technical Chat' started by mirco, May 12, 2009.
  1. mirco
    mirco Member
    LaGrange Ohio
    A couple of weeks ago I posted a thread in which I asked for help regarding an issue I was having with my 750 Seca. When the bike would warm up sometimes it would start running rough and it would be all I could do to keep it running. Sometimes no matter what I did the bike would stall and I would have to wait a couple of minutes and then it would start up and I could ride again for anywhere between just a few more miles and twenty miles or more. I suspected it was either I had a piece of dirt in one or more of my carbs that would slosh around and get stuck in some port once in a while or else it was the petcock.
    I replaced the petcock, the fuel filter, and I cleaned the bottom half of the carbs and the problem is solved. Since I did all three of these things while I had the tank off I am not 100% sure which one it was but if I had to guess I would say it was the petcock based on the fact that when I was draining the tank I had a trickle of fuel flow in both the run and the reserve positions. This leads me to believe that the diaphragm was not working correctly if at all. When I installed the new petcock, fuel filter, and reinstalled the carbs and turned the petcock to prime, the gas flowed beautifully into the carbs and I hit the starter and it fired right up. I turned the petcock to the run position and I have put 70 miles on it over the past two days with no problems.
    The symptoms were a severe stumbling and loss of power and seeming to only run on two cylinders. So I thought maybe this would be a help to someone else if they are having running issues.
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Just sounds like you were on the right track with checking for a fuel delivery problem. It could also be a plugged vent in the gas cap could cause similar problems.
    MN
  3. dpawl31
    dpawl31 Member
    NH, USA
    Sounds like it was the carbs to me. Petcock would have more than likely affected all 4 cylinders, not just two.
  4. bill
    bill Active Member
    Raleigh, NC
    Actually we debated that a bit, I contend that since the feed is serial if there is only a trickle and the needles are open then 1 and 2 could get most of the trickle since the feed is between them. Normally plenty of fuel flows to fill all 4 carbs.
    Anyway great to here you got it resolved! It always feels good to slay the dragons.
  5. mirco
    mirco Member
    LaGrange Ohio
    It was as Bill stated - 1 and 2 got all th gas and three and four were cold. I am pretty sure it was the petcock as the carbs looked pretty good. I had cleaned them pretty thoroughly last year and they still looked good.
