Lube your speedo/tach cables!
Discussion in 'XJ Technical Chat' started by SecaGirl, Sep 19, 2006.
  1. SecaGirl
    SecaGirl Member
    Arizona
    Just a reminder, if you're putting your bike up for the winter, or have noticed that your speedo/tach needle is bouncy.
    At highway speeds, my tach would bounce around 500 rpm to either side of the engine speed. This fixed it right up.
    After pulling the cable & tube off the bike, I cleaned the cable with WD-40 then used high pressure grease on the cable as I put it back in the tube.
    Oh, and used some teflon pipe tape on threads for the tach to engine connection. It'll help seal it up, since it's only a plastc screwcap.
    Plus, you'll get a chance to check the condition of your cables.
    Happy lubing!
  2. Altus
    Altus Active Member
    London, Ontario
    I'll second this one - and add that a proper cable luber is cheap, and you can use a good aerosol lube like PJ1 in your cables - it does wonders.
  3. OU812didntU
    OU812didntU Member
    good advice secagirl and Altus you allways forget about things like that until it snapps and breaks.
