M-unit + Reg/Rec Rewiring Question
Discussion in 'XJ Technical Chat' started by JoeyXJ, Mar 15, 2025.
  1. JoeyXJ
    JoeyXJ New Member
    Hi gents,
    This may be a very simple question for those experienced with electrical - so please bare with me.
    Purchased an XJ, getting it on the road but it came with no wiring harness.
    I am rewiring the bike with a complete new harness and an m-unit.
    Currently wiring the regulator rectifier.
    I have all the whites from the alternator joined to the whites on the reg/rec. Same with the green.
    Black to ground.
    I have red and brown from the reg/rec joined together going to the Alternator brown (field coil power) and this is then connected to fused key power from the battery +VE.
    Can anyone see an issue with this?
    Factory wiring diagram has two seperate circuits for this, but I can't see a reason to have two with the m-unit?
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    Red is hot all the time from the battery and brown is switched with the ignition....I don't know why but I would wire it the same as the factory did. If they would've been able to combine those connections into one they would've done it from the get go.
  3. JoeyXJ
    JoeyXJ New Member
    Thank you!
