M unit
Discussion in 'XJ Technical Chat' started by Nic, Nov 26, 2016.
  1. Nic
    Nic Member
    Philadelphia
    Anyone have a m unit if so can you explain how you wired you're bike
    there are a few threads on them.
    it is a power distribtion/control block that eliminates many wires
    "The m-Unit V.2 is a digital control unit for your motorcycle - the 'heart' of the vehicle's electrical system."
    https://spieglerusa.com/motogadget-m-unit.htm
  3. Nic
    Nic Member
    Philadelphia
    Thanks have you ever used a m unit?
  4. XJ550H
    no the 300$ plus pricetag is too much for me .
    it allows for led blinkers and all the gizmos.
    you can reduce the wires by using it in conjuction with the M button . go to the link and look at the wire diagrams.
  5. Nic
    Nic Member
    Philadelphia
    I wanted to take carbs off and rebuild I was told to stuff the holes with rags any suggestions the bike has waterproof cover is outside
  6. k-moe
    Lightly oiled rags to keep crud and vermin out works (the smell of the oil will keep mice from chewing through the rags). Making blanking plates out of plastic or metal flashing works better though, because you can seal those with RTV to help keep condensation out. If you can manage tings so the carbs go back on in a day then the rags will be fine. If you're like me and have multitudes of things get in the way of your shop-time, then make blanking plates in case you're unabl to get back to it for a few weeks.
    Nic and Stumplifter like this.
  7. Nic
    Nic Member
    Philadelphia
    Thanks I work 10 and a half hour days so yeah I would not have a entire day to do it plus never did it before.
  8. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    That... M Unit thingemie... is a cool idea! But I agree $300 bucks is WAY too steep.
    I'll give em $8.
  9. jayrodoh
    jayrodoh YimYam
    Cleveland
  10. Nic
    Nic Member
    Philadelphia
    Did you rewire your bike if so how?
  11. XJ550H
    this is a minimum wiring diagram
