MAC 4-1 with gaskets
Discussion in 'XJ Technical Chat' started by Kylew11, Jul 25, 2011.
  1. Kylew11
    Kylew11 Member
    Victoria, BC
    I haven't had a problem with the stock exhaust to date other than the fact that it rusted out. I got my brand new MAC 4-1 kit to install. I also had new exhaust gaskets. Upon firing up the bike it was immediately obvious there's a leak out the gaskets. does anyone know exactly which gaskets belong on my bike to properly seal a mac 4-1 system? are they the same gaskets as with the stock system? any and all input will help.
  2. Polock
    should be the stock gaskets, loosen it back up and give it a few wiggles, maybe it isn't seated right
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    When I replaced my MAC 4 into 1 I doubled up on the gaskets and used hi temp copper silicone to get a good seal. Like Polock said make sure the pipes are centered. Be careful not to over tighten the flanges they bend easy.
  4. Kylew11
    Kylew11 Member
    Victoria, BC
    I ordered some of the aftermarket gaskets.. From what I can see they will not work. The OEM ones are flat copper gaskets, correct?. Anyway, I didn't expect them to differ by much but these aren't Functional for me at all. Does someone have a pic of OEM vs. Aftermarket?
  5. Kylew11
    Kylew11 Member
    Victoria, BC
    Never mind, I found it.. http://www.xjbikes.com/Forums/viewtopic ... haust.html
    Has anyone else used the aftermarket gaskets with the Mac 4-1 system?? The metal OD of the gasket is spot on with the OD of the header so in my opinion it's guaranteed to leak. If someone can inform me otherwise I would appreciate it. Also, if i were to order the OEM gaskets, is the OD of those the same as the aftermarket ones? does anyone know the size? Meanwhile, I'm trying to find some gaskets locally so I don't have to wait another week to ride my bike that's been out for 5 weeks already!! BOO
  6. bigfitz52
    There are PICS of BOTH styles in my how-to you posted the link to.
    Other than material and "style" of construction, dimensionally they're virtually identical. They kind of have to be to be interchangeable.
  7. Kylew11
    Kylew11 Member
    Victoria, BC
    so my next question is, have you installed a mac 4-1 system using the aftermarket gaskets or the oem ones? I have the aftermarket ones and the diameter of the aluminum outer ring is the same size as the flange of the header. It will be impossible to create a seal against that. the stock header has a nice flat face that mates well with the element contained within the two rings, I just wish the new exhaust system was that easy. I just need someone with hands-on details about this system with the two different gaskets. Since there shouldn't be any difference between each gaskets in terms of OD, I doubt the copper OEM ones will work properly either.. i'm going to pick up the OEM type after work.. i'll post some pics later to help illustrate the point.
  8. Polock
    i used the ones from Len "chacal" and never gave it a second thought
  9. Kylew11
    Kylew11 Member
    Victoria, BC
    you used the OEM ones or the Aftermarket ones? and you used them on a MAC 4-1 system? the ones I have now are the aftermarket ones from Len. The problem isn't in the gasket, its that the mac system has a different mating face with the gasket. i'll post pics later to illustrate the point.
  10. wizard
    I always set the gaskets in clear silicone (both sides) makes a perfect seal, but can be peeled off next time.
  11. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I used the aftermarket gaskets when i put my MAC 4-1 on. It leaked when I first started it up, only cause I was being a pansy with the torque lol.
    Wrenched it down a bit more and it's sealed fine, the tabs didn't bend at all.
    Now i gotta find a solution to changing the oil without dumping oil all over the nice new exhaust (the actual 4 to 1 is right under where it would drip) lol.
    Figure i'll get some cardboard and bend it so it fits in between #2&3 headers, use it like a V type funnel into my oil pan. This is WITH the spin on filter adapter.
  12. Polock
    there was no yamaha sticker on the bag so i guess they are after market, yes mac 4/1.
    something to look at is the angle that the pipe meets the head, if the collector end is high, that puts a space at the top of the exhaust port.
    before i had the bracket made i tightened the nuts till they just touched the flange and moved the collector end up and down till i felt the pipes being flush in the head, then block it up there and tighten the flanges
