main jet sizes
Discussion in 'XJ Modifications' started by casperdog21, Jul 5, 2011.
  1. casperdog21
    casperdog21 Member
    united kingdom
    I am at the moment cleaning and checking my carbs, My question is what are the correct main jet size {xj650 1981} the main jets that are in have 925 stamped on, :? it is a lot different from the ones you guys talk about, The bike ticks over ok but when you open the throttle it hangs back and then its off like a rocket, its not the control I require, hope someone can help
  2. moellear
    moellear Member
    Lima, Ohio
    mine (same bike possibly? - non YICS) have "120" and "RD" stamped on the main jets. from what I recall, 120's are common for over here in the states. not exactly sure why 925 or what it means..
  3. matie69
    matie69 Member
    Norfolk
    Hi there
    27-925 is Mikuni part number for a 157.5 large round jet....??Fits N100/604
    Possibly that this is size of the mains already fitted to your bike.
  4. lancial
    lancial New Member
    well idk what my jet size is. but i know that those 650s dont make real power until 4000 rpms. so maybe its just ur mind playn games
  5. chacal
    Stock jets:
    Main fuel: #110
    Pilot fuel: # 40
    Main air: # 50
    Pilot air: #195
    Main jet needle: Size Y-10
  6. Threefingers
    Threefingers New Member
    Tennessee
    I've got a 82 xj750 Maxim i'm rebuilding the carbs and wondered if anyone could tell me what jets i would need if i have drilled 8 holes in each side of the stock mufflers and i am going to put a filter on each carb. or would the stock jets be ok ?
  7. wizard
    Rule of thumb after fitting pods, is 3 up on the mains & 1 up on the pilots.
