Master Cylinder Relocation
Discussion in 'XJ Modifications' started by Henry, Mar 23, 2008.
  1. Henry
    Henry New Member
    Canada
    Hi, first time posting. I have a 1982 650 Seca. I'm nearing the end of my winter work. I'm slowly turning my Seca into a Cafe Racer. Right now i'm looking to pick up some parts of MikeXS. My main question is regarding Master Cylinder, i was going to replace the one i had and noticed on MikeXS that he has some "custom" Master Cylinders. Just wanted to know if i could use what he has there on my Seca. I'm assuming that if i was to use one of the custom ones that i would have to relocate the Master Cylinder from the handle bar to the frame some where.
    The Page the "custom" Master Cylinder's i was looking at:
    http://www.mikesxs.net/mikesxs-chassis. ... ory_id=1.2
    I was looking at parts:
    Part #08-4001, 08-4002, 08-4000
    Thanks in Advance
  2. danno
    danno Member
    Union Springs,New York
    Hello,and welcome to the site! The master cylinders that you listed are rear master cylinders.If you are running a single front disc,try either #08-0262,or #08-4003(no mirror mount hole). If you are running dual discs,# 08-0255 or # 08-0265 should work for you. If you are using clubman bars,you may wish to a "sloped" master cylinder,such as # 08-4004(no mirror mount hole). Hope I didn't just add to the confusion,and best of luck to you!
  3. Henry
    Henry New Member
    Canada
    Thanks for the reply, i guess i wasn't really clear with my question. I actually wanted to know if i could use the "custom" master cylinder and bold it on to the frame some where as i didn't want to have the standard master cylinder on the handle bar. I wanted to clean up that area.
    But danno's answer did help me come to another questions is there a difference between using the handle bar master cylinder and a rear master cylinder? I was hoping all i would need to do is find a place to mount the rear master cylinder and run a line to it.
  4. Nick
    Nick Member
    Vernon, BC Canada
    Welcome to the site Henry. The 750 secas have a master cylinder that is attached behind the headlight bucket, pretty much on the frame. It is operated by a short cable.
