Master cylinder won’t build pressure
Discussion in 'XJ Technical Chat' started by Drake, Jun 15, 2018.
  1. Drake
    Drake Member
    New Zealand
    Okay guys my stock M/C was stuffed from previous owner crashing the bike.
    81 650 maxim single front brake
    So I fitted a early 2000s Yamaha R1/R6 master
    Brand new braided line
    New master rebuild kit
    New seal kit for calliper
    Been pumping for about 15min and I can’t get it to build any pressure..
    was I ment to bleed the master somehow before installing or something?
    Hate dealing with brake fluid..
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    try this... gravity feed it to start.
    open the last bleeder on the line and open the MC and keep it topped up, when you get flow without bubbles close the bleeder.
    top up the MC and tap the lines up to it so it releases any air bubbles up to the master and just partially squeeze the lever so the air ends up in the MC.
    Then... bleed as per usual.
  3. k-moe
    ^works every time^
  4. Drake
    Drake Member
    New Zealand
    Woo we have pressure you guys are awesome!
    So now I’m bleeding it like usual and I’m getting these tiny little bubbles come out into the reservoir will these stop?
  5. k-moe
    They will go away eventually. Tap the master cylinder a bit while you have the lever pulled.
    Once things are suitably firm you can go ride it to shake the rest of the trapped air loose , and then bleed the brakes one more time.
