MATH WIZ. Or Engine head HELPPP!!
Discussion in 'XJ Technical Chat' started by tyler93, Jan 31, 2009.
  1. tyler93
    tyler93 Member
    methuen
    Very stupid question but cant seem to find an answer
    Is 0.50 , 0.020?
    If that doesnt make sence is 0.50 equal to 0.020?
  2. turtlemann14
    turtlemann14 Member
    ... converting metric over to imperial or visa versa(sp)?
    either way no....
    and .5 is not = .02 in the same system either
  3. wizard
    0.5 or 0.50 = 1/2, but 1/2 of what, if you don't put something after it, i.e. inch, millimeter......................
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    0.02 in = 0.508 millimeters
    and 0.508mm = 0.02 inches
    Maybe that's what you wanted?
  5. tyler93
    tyler93 Member
    methuen
    iam talking about bore size so mm..
    I was told that .50 is equal to 0.020 in the mm.
  6. tyler93
    tyler93 Member
    methuen
    0.50mm is 0.020 in inches.
    Is this correct
  7. tyler93
    tyler93 Member
    methuen
    0.020" (0.50 mm)
    Right? The top of my piston said .50 so i called i guy and asked what size it was and he said it will be a 0.020 oversized piston
  8. Robert
    I'll confirm for you Tyler93 that 0.5mm is equivalent to 0.020".
    You have a set of oversize pistons there!
  9. tyler93
    tyler93 Member
    methuen
    Thanks i got a scare that i ordered the wrong parts
