Max carbs on a seca
Discussion in 'XJ Technical Chat' started by Xjrider92117, Oct 26, 2016.
  1. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    If I use carbs from a max on a seca (both from a 550) is all I need to do is swap the needles and pilot air jet? Can I just change the whole diaphragms over? Any info would be great!
    Jim
    you can swap the whole diaphram/slide assembly .
    pilot air jet swap as well.
    the pilot air jet and slide needle (Main jet NEEDLE) are the only differances between the two bikes carbs
    Xjrider92117 likes this.
  3. Xjrider92117
    San Jose Ca
    Thanks. That's what I wanted to hear! I think I'm gonna have a lot more questions coming up about the seca since I just started messing around with it today for the first.
  4. XJ550H
    maxim 550 cams
    seca 550 cams
  5. Marl
    Marl New Member
    Indiana
  6. XJ550H
    yes they are a little hotter than maxims, making the seca a little quicker and faster
    the larger diameter rear tire helps as well lowers rpm at cruse speed gives a higher top end
    Marl likes this.
