Maxim 650 turn signals?
Discussion in 'XJ Technical Chat' started by HeadlessRider, Jun 27, 2011.
  1. HeadlessRider
    HeadlessRider New Member
    Virginia, USA
    I searched for this question but I didnt see it come up. So do signals on a 550 and 700 work on a 82 650? Also maybe someone has some cheap signals or know of a site I can buy some?
  2. SQLGuy
    SQLGuy Well-Known Member
    AFAIK, the '80's XJ's use very similar turn signal systems, though different actual stalks. If you search some more you should find some pictures members have posted of mixed-n-matched signals from one XJ on another XJ. I think Chacal has some good info in his catalog as well.
    The main issue is that any signal you use should use 27W bulbs, unless you are interested in modifying the flasher/cancel system.
  3. HeadlessRider
    Virginia, USA
    Ah thanks for the tid bit. Good to know about the 27W bulbs!
