maxim 700 trike
Discussion in 'XJ Modifications' started by maximtrike, Apr 28, 2013.
  1. maximtrike
    maximtrike New Member
    ireland
    alright guys, after a stressful couple of weeks of trying to figure out my wiring loom, i have it sorted now havent had the engine running yet, but it is turning over and getting spark so shouldnt be too bad form here on out fingers crossed, anyway my plan is to build a nice low short trike, i will get cracking on it now soon and will have more to update pics etc hopefully it turns out alright now!
  2. 750E-II_29Rbloke
    South Cheshire, UK
    Cool glad you stuck through the wiring, sounds like all is well with that for now. Did you get that CB750 frame at all? Will be following this with interest as you don't see many XJ trikes :)
  3. maximtrike
    ireland
    yea got the wiring sorted i actually got the full manual for bike sent to me online from a guy on an american site, 2 hundred and something pages it is so its handy wiring was simple enough after, have spark and all now but havent ran it, didnt get my hands on the frame yet will when funds allow it will be der for me anyway im told so not too bad, but that is my next thing needed for to get any further along with this....thanks again for ur help
    also there is an xj 900 trike for sale on adverts.ie only one pic of it if ya were wanting to check it out! :D
  4. scrubby
    scrubby Member
    bevent Wi
    One suggeston is to put a good dampener on front wheel they have a habit of pulling to one side with an open differential in the rear a locker is not the way to fix this tho as they will have a very hard time turning.
  5. scrubby
    scrubby Member
    bevent Wi
  6. 750E-II_29Rbloke
    South Cheshire, UK
    Good point, or maybe build/buy a set of leading link "Earles" type forks.
    Steering a trike with locked diff is based on the Ouija board principle I believe, unpredictable & dangerous, the more you try to influence it's course the more miserable your outlook becomes :D lol
  7. k-moe
    An adjustable limited slip would be best. Maybe one from a late model Subaru?
  8. 750E-II_29Rbloke
    South Cheshire, UK
    I thought about that, but surely an LSD would be the "worst of both worlds"? Open diff in a straight line hence pulling, limited slip in corners causing understeer.
    What you'd really want would be a "limited grip" diff that was locked until a certain torque difference left to right & then allowed to slip...
  9. scrubby
    scrubby Member
    bevent Wi
    I have put selectable lockers in a few trikes at the owners request only to pull them back out a month or so later one guy made it five miles turned around to have it pulled out a good damper will help more than anything. The main problem I see is caused by the crown of the road. You can never get both turning and straight line set perfect but only a happy medium of the two. Now I have only deal with auto differential in trikes. Maby try to find a can am spyider front end and adapt that? Or one of the Chinese three wheel power cart rear end?
  10. k-moe
    Viscous limited slip diff. Never fully open, never locked, always splitting power evenly. Sources: Mazda MX-5, Nissan 250SX, all late model Subarus (2000 and on).
    Of course.....if the trike was really narrow......wouldn't need a diff at all.
  11. mtnbikecrazy55
    well shucks, lets ride sometime, I'm in point.
  12. scrubby
    scrubby Member
    bevent Wi
    Good thought on that k Moe and yea look me up I fifteen miles north of point
