Maxim vs seca
Discussion in 'XJ Modifications' started by serr73, May 17, 2006.
  1. serr73
    serr73 New Member
    Lansing Mi
    New XJ owner. Can anyone tell me if the seca handlebars are square like the maxims?I would like to put a seca fairing on my maxim, but I'm not sure if they're interchangeable?
  2. Robert
    Square? I'm not following. Would you be referring to the rubber covers that Seca's have on their handlebars? I'm confused. Pictures?
  3. serr73
    serr73 New Member
    Lansing Mi
    The bars on my maxim are square not round.I was told the secas might be round and cause a problem for interchanging parts.I am having trouble uploading pics at this time.
  4. Joel07
    Joel07 Member
    Durham, NC, USA
    I'm assuming you have the oddball ones that are square machined aluminum with a splined end that bolts to the front forks. Certain year Seca's had them also, but I have no idea what years had them. No idea why they did that crap, my '83 Venture has the same thing... :roll:
  5. serr73
    serr73 New Member
    Lansing Mi
    Yes my bars are the oddball type.Is there anyway to switch them out? This is a new bike I just accquired so I don't mind spending$.
  6. Joel07
    Joel07 Member
    Durham, NC, USA
    I'm not sure how you would go about switching them other than a fork swap, which isn't too hard if you have another set of forks to try. It would give you a good opportunity to also swap to a dual-disc front end, either off of a Seca or XS750/850.
  7. Robert
    Oh boy, I'm in over my head. I've never seen square handlebars anywhere. I'll leave this one to you enlightened ones.
  8. jasonlion54
    jasonlion54 Member
    Seattle, WA
  9. serr73
    serr73 New Member
    Lansing Mi
    Thanks for all the help, I will see what I can do. Pictures are now posted!
  10. dcmilkwagon
    dcmilkwagon Member
    Hancock, Iowa
    Don't feel like the Lone Ranger, Robert, I've never heard of them either. Strange looking critters aren't they? :lol:
  11. Joel07
    Joel07 Member
    Durham, NC, USA
    So is your goal just to get some lower, flatter bars? If so, I think it'd just be a matter of finding the same style Seca bars. In fact, I have one here (I think, could possibly be a Maxim bar). I'll try to take a pic of it for comparison purposes...
  12. thedude
    thedude Member
    Columbus, ne U.S.
  13. brad020
    brad020 New Member
    West Michigan
    I have an 82 Maxim 750 w/ square bars. I have actually swapped to round bars in the past, (but switched back b/c my bars weren't comfortable).
    The top triple clamp is similar between bikes. Usually (with round bars) there are handlebar pinch clamps that have a threaded stem. The stem is bolted through the triple clamp and the bars are installed.
    The square bars have a similar setup, if you take them off, you'll find the base of these bars come down to 2 holes in the triple clamp, they bolt on essentially like round-bar clamps.
    In my case, I went to the scrap yard and found a pair of random round clamps. I made sure the threaded stem was long enough to do the job. Trouble was, when I got home, the stem was larger than stock. I drilled out the holes in the triple clamp and put 'em in.
    Worked okay, but of course had to re-route some cables, etc.
    When I switched back, I had to use spacers on the stock stems because I had oversized the holes in my triple clamp.
    With more attention to detail, you may find a direct interchange.
    If you want me to post some pics, just holler.
  14. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    The '83 Maxim has round bars. You could just change these out for yours from a parts bike. Haven't seen the square bars up close but make sure you check the risers. According to the parts catalogue you will need to change them also. www.denniskirk.com sells replacement bars, so for about $35 you could have a new shinny set.
  15. CTSommers
    CTSommers Member
    Philadelphia, PA
    Only the 1981 to 1982 Seca and maxim had the square bars. A easy way to tell is if the front light is square so are the bars. Round front light round bars.
    All xj650 had the round bars.
    Also the XJ750 Seca has slightly lower gearing I’ll check my 1983 issue of cycle magazine if you want the specs.
  16. serr73
    serr73 New Member
    Lansing Mi
    Thanks again,That last pic looks like my bike.I'll start paying attention to the headlights a little bit more now, Also the link that thedude sent was helpful.I'm gonna order them bars here shortly I will post pics when I get them on.
  17. Nick
    Nick Member
    Vernon, BC Canada
    My 82 seca has round bars under the plastic coverings and has the rectangular headlight with the lower rectangular auxillary light.
  18. BlueMaxim
    Central Mississippi
    Well I screwed the pooch on that one. Was looking through the dk catalogue today and noticed the handlebar prices had gone up dramaticly. Seems I was looking for bars when I first started restoring my XJ and they were about $20. Those suckers are about $80 now! My appologies. Man , it was only 3 years ago I started on this bike....can't believe how they went up.
  19. Robert
    Steel, as with most materials, has climbed in price, keeping pace with the cost of oil. Import and transportation costs are a big player in the prices we pay nowadays.
  20. BlueMaxim
    Central Mississippi
    Man has it climbed in price!!! I like your Avatar Robert. I feel just like that after filling up the gas tank.
