Maxim X Carb Cleaning
Discussion in 'XJ Technical Chat' started by Tarezo, Nov 20, 2008.
  1. Tarezo
    Tarezo New Member
    Minneapolis
    Hi All,
    I have been reading through all the posts on cleaning Mikuni Carbs, including some excellent detailed instructions with photos.
    I am going through mine now because they're off the bike in order to do a valve adjustment.
    Removing the floats to get to the float valves underneath involves driving a small pin from the two posts on either side of the float. The great danger is breaking off one of the posts. There has been a lot written on how to do this, but there's always a chance that things will go badly.
    Here's my question: Should I just skip this one step to avoid the 'breakage risk'? I have not had any problem with the way the bike is running and have no reason to believe there's a problem with valve.
    On the other hand, if I break off a post I'm in trouble big time.
    Any opinions?
    On another note, I had to extract one of the float bowl drain screws and it's no longer usable. Anyone know where to get replacements?
    Thanks.
  2. chacal
    Yarezo, I carry both the original and replacement allen-headed carb bowl drain screws in stock, drop me a note for all the details.
