Maxim X Thermostat Problems....
Discussion in 'XJ Technical Chat' started by xRedemptionx, Oct 10, 2011.
  1. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    I was having problems previously with the fan fuse blowing every time i rode for more than about twenty minutes, so i, for the time being, disconnected the fan from the wire off of the thermostat switch, and ran power through a handlebar switch i had(aftermarket bar switches).... i was looking today and saw that on the thermostat housing there is a green wire with a red stripe that is fried and the post it should connect to is awol.... like looks cooked and is gone. is this just the signal wire for the fan switch?
  2. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
  3. Tito
    Tito Member
    Barto, PA
    My guess is the connection was not tight enough there causing arcing wich creats excessive current and blows the fuse and . If there is enough metal left on the post you can solder the wire back on give your other female terminal a squeez with some pliers to tighten it up before you slide it on the post.
  4. schmuckaholic
    California
    Patience, Grasshopper. Give us some time to look it up.
    According to my factory manual, The green/red wire runs from the temp gauge, through a connector (probably in the headlight bucket) to the thermo unit, and from there to ground. It has nothing to do with the fan.
    The thermo switch is what turns the fan on and off, and has Brown and Blue wires going to it.
    (Two temperature sensors in this thing? Who knew?)
  5. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    excellent. thank you guys so much... i'm not running stock gauges so it shouldn't be a problem... sorry to be antsy i have a run i was going to go on tomorrow and didn't want to ride without knowing for sure it wouldn't destroy my bike...
    unfortunately the metal does not look like it has anything left to solder to... i need to see...
