Maximum front tyre size
Discussion in 'XJ Modifications' started by Drake, Feb 26, 2017.
  1. Drake
    Drake Member
    New Zealand
    Hi guys
    Has anyone experienced what the maximum tyre size that will clear the forks?
    Not worried about fender clearance just forks.
    Thanks in advance
    Which Maxim? There's about five models that bear the Maxim name, all with different tire sizes.
  3. Drake
    Drake Member
    New Zealand
    Sorry 1981 special
    Currently has a stock 100/90/19
  4. Simmy
    that is precisely the tire you want. A 110 is too big and will slow down the handling.
  5. Drake
    Drake Member
    New Zealand
    Thanks for that I am not worried about hindering handling performance.. just after a bigger stauncher look. Fully custom build.
    Will be fitting Daytona 675 forks later on in the year anyway.
  6. k-moe
    Same advice as above. No sense spending money on a tire when you're going to be sepnding money on tires again in less than a year anyway.
  7. Drake
    Drake Member
    New Zealand
    Still interested to know what others have done regardless
  8. k-moe
    Your first limitation will be the front rim width, not the forks. Going two sizes wider than stock is the bare edge of what I would consider safe.
    A fella many years ago was making a kit to fit a rear wheel and tire combo on the front. A search should pull up the thread.
    Drake likes this.
  9. Drake
    Drake Member
    New Zealand
    A fella many years ago was making a kit to fit a rear wheel and tire combo on the front. A search should pull up the thread.[/QUOTE]
    Taking in the account the width of the rim even if i can get a 110-90 in or a 3.5/3.75 in I would be content for now.
  10. Captn_Obvious
    Captn_Obvious New Member
    PL
    I recently put a 110/80 on my '84 750 seca and it works great.
  11. hogfiddles
    He also STOPPED making them....
    You could see if this is still available.... it has that rear-to front kit on an xj650 maxim.
    https://ithaca.craigslist.org/mcy/6011363207.html
    Personally, I wouldn't waste any $ on it
