Mechanical Speedo-Which part is is the common one that fails
Discussion in 'Hangout Lounge' started by Metal_Bob, Oct 26, 2010.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    This is just a curiosity question.
    On XJs with mechanical speedo hubs on the front axle, which part in the overall assembly tends to fail? The axle hub, the cable, or the actual gauge?
    I see alot of post here and CL about the speedo (and/or mileage indicator) dying. So I'm just curious which part(s) are the common weak link?
    Any specific comment about the 82 750 Maxim weak links?
    FYI: Mine is currently working, but I'm a curious person. :wink:
  2. tjb2of3
    tjb2of3 Member
    Charlotte, NC
    When I got mine, the speedometer worked but the odometer didn't. So that's a gauge problem. Then, after about a month, the cable broke down by the axle. Maybe I just have bad luck.
  3. BillB
    BillB Active Member
    Tulsa Oklahoma
    I broke mine too. Shortly after I learned the gears would not strip
    Inside the speedometer it routine maint is performed.
    I recently found a replacement for mine.
    Its a iPhone app.
    A lot of guys preach about maintenance on the speedometer.
    I you search the forums you can avoid the thing breaking by taking the speedometer apart and doing this.
  4. bigfitz52
    Any of the usual suspects, actually.
    Take a look, here's what's in there: http://xjbikes.com/Forums/viewtopic/t=15303.html
    -inner cables wear, become "snaggy" fray and break.
    -cable sheaths get worn thru, allowing water incursion and rust to develop.
    -speedo gearbox at the wheel often needs cleaning and lube, and doesn't get it, so it will eventually fail.
    -a hamfisted PO will often mash the "ears" on the drive gearbox flat when reinstalling the front wheel.
    -the instrument itself can "pack up" from becoming gummy/lack of lube; the input bearing often fails, or the little internal gears can strip/grind themselves up because of being gummy/sluggish.
    (Take a look at how the instruments are made, in the link I posted.)
  5. Metal_Bob
    Bourbonnais, IL
    Great post and comments here Fitz!
    I've seen that post before and forgot about it.
    I have a spare part/junk? atari cluster if I ever need gears and pieces.
    I might eventually pick up a spare cable and wheel hub just in case.
