Wanted michael moberg needs a starter
Discussion in 'For Sale, Trade/Swap, Wanted' started by hogfiddles, Jul 5, 2023.
  1. hogfiddles
    Please respond HERE, or @michael moberg ....... rather than a gazillion different forums.
    He needs a starter for:
    XJ 650/700/750/X/900
  2. chacal
    We have new and rebuilt ones in stock!
    DarbyC and hogfiddles like this.
  3. michael moberg
    michael moberg Member
    vallejo, california
    Thanks for your help..........
  4. Wingedwheel
    Wingedwheel Member
    MI
    I have one.
  5. michael moberg
    vallejo, california
    Who's got a starter......2025
  6. michael moberg
    vallejo, california
    Immm. Looking. For. Starter
  7. hogfiddles
    1. Chacal has already posted that he has them
    2. Wingedwheel has post that he has one
    have you had a conversation with either of them yet???? It’s been over 2 years and you’re still posting??
  8. michael moberg
    vallejo, california
    Still need one
  9. hogfiddles
    Well, in fairness to the bike,
    -if you want a kickstart bike, go get a kickstart bike.
    -Many replies were made on where to get a starter, didn’t seem like you were taking them up.
    -Typically, a rebuild kit will solve the issue. If not, typical a readily available replacement will solve the issue. If not, typically, opening the engine a replacing the starter gear inside solves the issue. If not, typically you did wrong.
    -Typically, these bikes are generally bullet-proof if they’re given reasonable preventative maintenance.it’s a rare instance to find an XJ lemon. MAYBE you got one, though I doubt it.
    now a few questions:
    what starter did you get?
    Where did you get it from?
    What starter gear assembly did you get, and where did you get it from?
    What manual did you follow to install it?
    Dfox
    Minimutly and Franz like this.
  10. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Like the bit about few real lemons, I've bought basket cases on pallets, with some carb cleaning they rode perfectly - so Yamaha got a lot right with these..
  11. michael moberg
    vallejo, california
    hogfiddle, i wont spend big money on one, the magnets inside breakup, the guts wornout....its a 650 turbo motor so the black boxes were different and the starter could have been a 750. i dont need a manual to put one in.its cut and dry except to shim it up. i got one that worked fine for 75. that my limit. how much is a new one.
  12. jayrodoh
    jayrodoh YimYam
    Cleveland
    Maybe you do, Yamaha never made shims for this engine and the service manual doesn't have a procedure for shimming the starter.
    You state in your other post that the "starter gear ingages then spins grinding gears" so:
    • Your battery is either junk or you have a wiring issue where the starter is not receiving the full amps the battery can provide.
    • The starter clutch is worn and will not stay engaged. You stated in the other thread that you replaced that though....big job.
    • The starter needs rebuilt. You haven't answered this one previously.
    These starters are dime a dozen, 80 - 83 650/750/900 Maxim/Seca and 85/86 700.......all the same. Easy rebuild, they are simply a motor. All the "engaging" takes place inside the engine on separate components.
    I'm having trouble understanding how you can go through the significant work effort and expense to replace the starter clutch but are struggling with a simple motor. Jumping on an XJ forum where there are many enthusiasts and stating "these bikes are a piece of shit" is not a great way to get help either.
    Starters are available brand spanking new for $400. If you've spent the money and time to do the clutch and are having trouble with used starters or the rebuild then maybe this is your best route.
    Simmy likes this.
  13. hogfiddles
    Shim one up? Not sure what you mean. You just push it into the hole, then install the long bolt and the short bolt, then attach the wire to the post.
    as has been stated before, check with xj4ever for a new one. If you don’t know the price of a new one, then you haven’t checked with him yet.
  14. michael moberg
    vallejo, california
    Thanks very much for your time replies. There's a history, I say that because I've gone the full Monty, replacing engine,rod through the upper casing,750 to 650turbo engine. It would have been junked by anybody else. 600.00 for an engine.....400.00 for a starter.... No, homey don't play that....im still in the market, I've got it starting first push of the button. Pat myself on the back. I rebuilt it before I rode it around the corner. Attitude problem, it dumped me going to the store like a bucking brocco. Pieces of shit......figuritively.....blood,sweat and $$$$$$. I'm past the junk,with the engine change. Its running for now. Haven't taken it out the yard working up the goomby. Shut it off, will it start.... Feeling. Thanks again for your input.....
  15. michael moberg
    vallejo, california
    400 for a starter......... !!!! I bought a xj1100, the whole bike for 200. its running.
  16. michael moberg
    vallejo, california
    Dime a dozen....i beg to differ. Partner....
  17. chacal
  18. michael moberg
    vallejo, california
    As of 5/13/25, the bike needs a starter. The present one is spun its final spin. I had two starter gears, changed the gear and that fixed the problem but now the starter doesn't even crank the engine. I took plugs out and it turned the engine but won't with compression. Fryed. So...any starters out there....that gentleman said there a dime a dozen. Ok.......thanks....
  19. hogfiddles
    Here we go again….
    There 7 on eBay right now.
  20. michael moberg
    vallejo, california
    Thank u. Purchased one 120.00 w/tax. Anybody have one cheaper. Came out of a 85 xj700 ,
  21. michael moberg
    vallejo, california
    listen, I just went on ebay, wtf.
  22. Rooster53
    Seems kind of costly, hopefully it is good but even working it should get a rebuild / inspection before installing just to be sure
    This one is cheap, but it's an auction so who knows where it will go. And not the prettiest of starters, but some fresh paint and rebuild might be a deal
    https://www.ebay.com/itm/365592511276?_
  23. michael moberg
    vallejo, california
    hey, I put in a bid of 30. Ty. He said there was 7, a another said there a dime a dozen. Right.....wtf.
  24. hogfiddles
    Yes. On MAY 13, 2025 I said there were 7 on eBay.
    BECAUSE THERE WERE SEVEN ON EBAY ON MAY 13.
    I have a dozen parts bikes and engines, I have starters all over the place, and three others in a box. They’re gonna stay right here. Y0u can rest assured ai didn’t buy any of the ones on eBay.
  25. hogfiddles
    Only took a couple minutes to look right now, too.
    IMG_7109.jpg IMG_7103.jpg IMG_7104.jpg IMG_7105.jpg IMG_7106.jpg IMG_7107.jpg IMG_7108.jpg IMG_7109.jpg
    of course there are some duplications…..,I haven’t edited anything. I’m not looking for any more, I’m not doing any more homework, I’m not saying any more, I’m not selling any. Why not?This ‘needs a starter’ thing has gone on far too long. THEY ARE PLENTIFUL. Go get one and be done with it, already.
    ‘Nuf said. I will try to refrain from saying anything else.
    jayrodoh likes this.
