Midnight maxim 4-1 exhaust
Discussion in 'XJ Technical Chat' started by xj750midnight, Sep 19, 2015.
  1. xj750midnight
    xj750midnight Member
    netherlands
    Hi everyone!
    I have a question! Can I fit a 4-1 exhaust of a XJ750F on my XJ750MK '83? Or which exhaust WILL fit? I have a 4-2 exhaust with a collectorbox right now, and I like to go to 4-1!
    Thanks in advance!
  2. hogfiddles
    You can, but why would you even want to?!?
  3. XJ550H
    yes stay away from 4 to 1 if you can. my 4 to 1 was touted as allowing center stand and oil access centerstand fits and works.
    can drain oil can not pull the filter housing past the pipes have to rotate it and change out filter with it between pipes,
    I an now hunting down parts for a stock exhaust
  4. xj750midnight
    netherlands
    I really LOVE the look of the 4-1 pipe! Maybe it is an idea to create an 4-1 pipe myself? So I CAN Reach the oilfilter?
  5. XJ550H
    well you will probaly have to rejet your carbs for a 4 to 1 system. there is a place on ine that sells all the parts you need$$
    xj750midnight likes this.
  6. xj750midnight
    netherlands
    I allready started rejetting since I run with pods... And no mufflers on de collector... I like the science and the testing, I know I should get rid of the pods aswell! ;) everything Will work best when original! But i like being Busy doing something i like!
  7. Polock
    if you get a spin-on oil filter adaptor the filter comes right out. Center stands work good in the garage, that's where i leave mine
  8. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Well if you like being busy, pods and open exhaust is the way to go! Keep us posted.
  9. k-moe
    Center stands work great on the road too. Particuarly when you need to plug a tire while on a sparsley traveled 2 lane, 30 miles from the nearest town.
    4-2 looks better to my eye. Balanced.
  10. XJ550H
    so your saying the oil filter is a smaller diameter than the stock oil filter cover?
    sounds like a good reason to convert
  11. Polock
    one of the filters that's used is a k&n hp-1008, outside diameter 2.7 inches. the stock cover is about 4.
    other filters fit but k&n gives the dimensions
  12. XJ550H
    heres a link for you
    http://www.coneeng.com/designing_motorcycle_header.html
    thanks for the info
    looks like another item for the list
  13. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    My 4-1 allows center stand use as well as oil filter access. On a 650 maxim though.
  14. quebecois59
    My Seca900 is equipped with a 4-1 (don't know the make) and I have no problem using center stand neither removing the oil filter. There should be minor differences from a make to another. I can't tell anything about performance, I've never had neither ridden a similar bike with a 4-2.
  15. darren ditmar
    darren ditmar Member
    eugene oregon
    i also have a 4-1 and i have no problems with it
  16. xj750midnight
    netherlands
    Thanks everyone for your answers! I See there's a separate opinion about the 4-1's, I think I Will keep my eyes open on the dutch sellingplaces for a "original" 4-1 system... And keep the open headers till I found one!
    Thank you for this website! I'll read through it when I have the time!
  17. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    The oem system should be 4 into 2 (four headers into two mufflers).
    Gary H.
  18. xj750midnight
    netherlands
    Thanks for Your reply! I know the 4-2 system is OEM, I do have the collectorbox underneath the bike now... That's why I used the "" with original! :)
  19. quebecois59
    I should add the 4-in-1 on my Seca900 has a Kerker muffler, but I have no idea what make the headers are...
  20. XJ550H
    i had a kerker system on mine but the headers rotted out at the collector found out it was a $800 exhaust system to replace,
