Wanted Mikuni BS35 carb(s) for '83 XJ900 Seca
Discussion in 'For Sale, Trade/Swap, Wanted' started by co.dirtbiker, Oct 5, 2024.
  1. co.dirtbiker
    co.dirtbiker Member
    Colorado, USA
    I discovered that the previous owner had damaged the #1 (clutch side) carb and tried to replace it but put in a BS36 instead of a BS35. Obviously, that's not going to work.
    All I need is the #1 but will consider anything you've got if they are interchangeable.
  2. chacal
    We should have a good used carb body. All the later ('85-up) XJ900's used BS36 carbs; they should fit and with some mods to the jetting can be pressed into service.
  3. co.dirtbiker
    co.dirtbiker Member
    Colorado, USA
    PM sent
