Mikuni Float Bowl Drain Screws
Discussion in 'XJ Technical Chat' started by domroc, Jun 7, 2007.
  1. domroc
    domroc New Member
    Connecticut
    Does anyone know where I can get a new set of Mikuni float bowl drain screws? I have seen the link on these boards to the Hitachi drain screws, but the ones on my Mikunis look different. They have a small o-ring on them.
  2. XJTurboDan
    XJTurboDan Member
    Seattle
  3. domroc
    domroc New Member
    Connecticut
    Thanks Dan! I've placed my order. Now, when I extract the old, stripped ones and put these in, what can I do so the new ones come out easy? I'm not so hot on forking over $4 for a fancy screw, so I'd rather not have to do it again. Could I use anti-seize or is that no good on rubber and/or carbs?
  4. Polock
    only tighten them enough to seal then a bit more
    when you change your oil loosen and re tighten them
    it's the twenty odd years of inactivity that locks them up
