Minimum Wiring / CDI Technical Question
Discussion in 'XJ Technical Chat' started by Craig Corbin, Jan 13, 2019.
  1. Craig Corbin
    Craig Corbin New Member
    Phoenix
    Getting ready to start an XJ550 motor on the stand. Have Pickups / ignition coils / CDI box to wire up. Pretty sure I have the schematic understood, but was wondering if anyone knows how much current draw I should expect. I want to fuse it on the stand so that any irregularities will cause the fuse to blow, an not burn up any components. Thanks!
  3. Craig Corbin
    Phoenix
    Yes and thanks! I saw where all the fuses in that diagram were 10amp, so Was thinking that they were a generic selection. Was hoping somebody had actual current draw for a healthy bike and that circuit.
  4. XJ550H
    main fuse is 20 amps
    signal fuse is 10 amps
    headlight fuse 10 amps
    ignition fuse 10 amps
    even on the min wiring diagram.
    your meter should have am amp tester typicaly 10 amp max.
    what you could do is start with a 5 amp fuse then go up to a 7.5 amp fuse if the 5 amp fuse blows, then up to 10 amp if needed. it is not like you have many choices.
    Craig Corbin likes this.
  5. Polock
    if the wires aren't right you can ruin things with one amp, on the other hand if the wires are right, you won't need any fuses.
    just make sure the wires are right
  6. XJ550H
    a dead short on the correct wires will burn things up with out a fuse. you at least need a main fuse
  7. Craig Corbin
    Phoenix
    I've ordered a harness, will wait until that gets here... patience is so hard! Thanks guys.
