misfire at hard throttle/higher rpm's
Discussion in 'XJ Technical Chat' started by Breaker19, Mar 21, 2010.
  1. Breaker19
    Breaker19 Member
    Bradenton, FL
    OK, yet another question.. thanks everyone for being so helpful thus far.
    On this '83 XJ900 I have been working on: I have a misfire during hard throttle at higher rpm's, like when I'm running hard through the gears. It feels like one cylinder is cutting out slightly.
    I have:
    - cleaned the carbs twice including the Clunk Test recommended procedures
    - pilot screws set at 2-3/4 turns plus or minus a couple degrees
    - float levels checked per the service manual (using the clear tubing). I had two out of adjustment and they have been corrected.
    - new plugs
    - checked timing - right on the dot
    - new vacuum line from the intake to the pet cock
    - valve clearance adjustment (required one shim change-out)
    - OE airbox
    - OE air filter
    - stock exhaust system
    - fresh fuel 93 octane (I completely cleaned out the tank and sealed it)
    Starts fine when cold without even having to full-choke it.
    I have not done a carb synch check yet, but that's coming soon as I can get to it.
    Also, when I just crack the throttle like cruising in 3rd gear it seems to want to hesitate a bit. Just a bit, though.
    So, besides doing a carb synch, any ideas of what to check next? Thanks.
  2. chacal
    Until you synch the engine, everything else will be just a guess...........!
  3. Breaker19
    Breaker19 Member
    Bradenton, FL
    Yea, that's what I was thinking. I was just looking to see if I missed anything. Thanks.
