Mixture Screw/Colortune Question...82XJ650
Discussion in 'XJ Technical Chat' started by rocs82650, Feb 3, 2013.
  1. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I need to get this right. I don't see a color change in the Colortune plug. Valves are in spec. Carbs sync'd. Bike starts and idles at 1050rpms. Mixture screws set at 3 turns out. Yics tool installed. Colortune plug installed. As I turn the mixture screw out the rpms slowly start to increase. Is it at this point that chamber is rich and I should turn the screw back in until the bike returns to normal idle? Do this for all four then sync the carbs again? Then plug chop and make adjustments as needed? Thanks.
    Gary
  2. bigfitz52
    No color change on any cylinder?
    What color were you seeing?
  3. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    To prove that I don't know it all, does the YICS tool need to be installed when adjusting the idle mixture? Since I don't know the answer to this question for sure, I theorize that with the YICS tool installed for this purpose, that it doesn't matter to the engine. But I could be wrong.
  4. bigfitz52
    According to Yamaha the answer is yes.
    Yamaha's procedure for adjusting idle mixtures involved the use of an EGA, with YICS blocked; and the ColorTune is our "visual substitute" for the EGA.
  5. rocs82650
    Middle Tennessee
    BigFitz,
    I'm seeing powder blue. Pipes yellowing at top bend and plug electrodes still white at 3 turns out. Thanks.
    Gary
  6. bigfitz52
    You're LEAN. If turning the pilots out isn't doing anything then your pilot circuits are still plugged up (or float levels horribly off.)
    Or you have a massive vacuum leak somewhere (or YICS isn't properly blocked, causing said vacuum leak.)
  7. rocs82650
    Middle Tennessee
    ok. thanks.
    Gary
  8. RickCoMatic
    Powder Blue is only Ideal for IDLE.
    You must add additional (Supplemental Richness) just beyond the Blue to prevent hesitation.
    The Supplemental Richness provides the Fuel needed to maintain combustion(s) during the BRIEF introduction of Fresh Air which precedes the Main Jet Supply.
    The Supplemental Richness involves turning the Mixture Screw OUT past the Blue about the width of a Nickel.
    The duration of Fresh Air preceding the Main Jet Supply is less than a second, but if not sufficiently Fueled, causes the Plant to hesitate.
  9. rocs82650
    Middle Tennessee
    Thanks.
    Gary
  10. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Thank you Fitz for the answer to my question.
