Mixture Screw Removal
Discussion in 'XJ Technical Chat' started by emre_xj_750, Mar 28, 2014.
  1. emre_xj_750
    emre_xj_750 New Member
    PortlandOregon
    After messing with this mixture screw which was stripped by previous owner I came up with a way to remove...1st I drilled a hole on the screw maybe 5/64" or so ...I drilled with reverse drill but it did not removed it while drilling so I stopped when I drilled 1/8" deep. I got an Allen wrench and ground the tip then hammered it in to the hole and twisted. Good luck!
