Montana mad max bobber
Discussion in 'XJ Modifications' started by Dobbie 76, Jun 4, 2016.
Good bad or ugly
  1. Hate it
    4 vote(s)
    44.4%
  2. Would ride it
    5 vote(s)
    55.6%
  1. Dobbie 76
    Dobbie 76 New Member
    Montana
    1465043891686-48013571.jpg Some reason can't get day one pic to upload got this 82 it was bone stock an hadn't ran in 8 years. I went through carbs flushed case an went to choppin. 20160525_200202.jpg added some blinkers a cast iron tractor seat and cushion.hammer out some cover panels added some racer stripes .new rubber. Had to put on some forward pegs and modify the brake pedal cause I can't bend my right leg much . From a crash a few years back 20160521_200305.jpg swapped rear shocks from a savage lowering 2 inches . Smoothed out tank made new gas cap . All in under 2 weeks 20160521_200305.jpg 20160525_200202.jpg 1465043891686-48013571.jpg 146504398166550292873.jpg 20160525_200202.jpg
  2. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    To my eye, the pad on the tractor seat with square pad looks a little odd, but I'd ride it. Also, the space between the seat and the tank...
  3. k-moe
    There ae padded covers meant for tractor seats. Getting one would greatly improve the look.
  4. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I am kind of getting tired of the bobber thing. It's like every other thread on here is about a bobber. That's just me, though.
    Purely in terms of design on this:
    The brick of a pad on the seat looks goofy. What the guys said - get a proper pad for that seat.
    The side panels - the gaps between them and the frame front and bottom look weird. Especially at the front.
    Having a tube over the fender stub connecting the frame ends in the back would make it look nicer to me. Or, some other way of dressing frame stubs.
  5. XJ550H
    still has the air box...
  6. k-moe
    What's up with the long hardware-store spring next to the clutch cover?
  7. XJ550H
    it is holding up his modified forward control brake pedal
  8. k-moe
    Surely there has to be a better way. That is expedient, but....
  9. Jetfixer
    If you like it that is all that counts , does not matter what anyone says!! I personally like a stock bike or "lightly" modified , but that is me.
  10. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Hey Dobbie, have you looked up drive shaft deflection on here? The universal joint when stock is at the correct/optimum angle for proper operation. Dropping it two inches will affect it negatively.
    Do you actually ride this on the street?
  11. jayrodoh
    jayrodoh YimYam
    Cleveland
    I'd ride it, minus the tractor seat. One thing I love about bikes is their owners and making their bikes theirs.
    Your exhaust looks decent on that. I spent almost a year searching out good original exhaust parts for my 82 resto, please don't hack those up. These are just old enough that some parts are getting very scarce.
  12. jayrodoh
    jayrodoh YimYam
    Cleveland
    A clutch cable from an 82 Seca is 7" shorter, that will cure the goofy clutch cable look. Chacal (Len) on here has both OEM and aftermarket ones available. You can re route your original choke and throttle cable to suit.
  13. Dobbie 76
    Montana
    Thanx 4 the imput. Used the rear shocks of my wife's savage which I've read is commonly done.and let all the air out the forks. I do ride on the street alot. I get alot of mixed opinions on the seat but it's actually really comfy 4 me . Im not a perfectionist at all I would rather be riding. My wife is xactly opposite.she spends all her time workin out every detail. While I'm riding she's in the workshop cussing . I hadn't really thot about the cable looking hinky. I might try an do something about that. I had to find a shorter kickstand 20160619_065300.jpg 20160619_065300.jpg
    Jetfixer likes this.
  14. k-moe
    The air in the forks doesn't affect ride height. It affects the effective spring pre-load. You can run air in there if you want to.
    A 2" drop at the rear is fine.
    Love the paint.
  15. Polock
    bingo! it's a wonderful seat
  16. Dobbie 76
    Montana
    My wife made me a seat out of buckskin and layers of compressed foam but it wasn't tall enuff so my back leg would drag on the iron while putting feet down so I got the thicker one. Plus the roads where I live suck so more pad is better 20160521_200242.jpg
  17. Dobbie 76
    Montana
    my wife hates that it'd red on one side and white on the other . But she's a flat black all the way type no flare. 20160522_231041.jpg
  18. Dobbie 76
    Montana
    I put air in front and it lifts it alot. And rides rough. Probley to much air it all leaks out in a day so I let it go . If I want a tall ride I take out my 79 650 special 20160514_202343.jpg
  19. k-moe
    5 to 11 PSI for a solo rider; 17 psi is max, and the front will not lift with the max in it.
    If it's leaking then you either have bad air collar o-rings, bad schrader valve, bad hose, or a leaky fork seals.
    If you don't want to fix the air leak you can make longer spacers to increase the spring preload (which is what the air is doing).
  20. Dobbie 76
    Montana
    I put some slime fix a fat in the forks sealed up haven't had to put in more air
  21. Dobbie 76
    Montana
    I painted it black don't nit ice it now
  22. k-moe
    Take that out now!
    The fork oil is not in a seperate chamber. The Slime will block the damper rod passages and possibly corrode the internals. The bits of thread in it will definitely cause problems.
