more frozen bolts
Discussion in 'XJ Technical Chat' started by oak450, Nov 18, 2008.
  1. oak450
    oak450 Member
    The foothills of Oregon
    I tried to change the fork oil. In order to do so, I had to loose the handle bar assembly, to get it out of the way.
    While trying to do that I broke both tops of the bolts that hold the headlight and speed/tach to the handlebar assembly. Very smooth.
    Don't know what to do. Tried the sears drill-out method on one bolt and it just stripped itself.
  2. bill
    bill Active Member
    Raleigh, NC
    Does any stick out? I would think some would since it holds the speedo assembly. If so you can try grabbing it with vice grips.
    If the easy out won't budge it you can try heat or penetrating oil to loosen it. Your other options are to drill it out and retap or drill it and helicoil.
    Best thing may be to take it to a local machine shop and let a pro get it out.
    A pic may help spur some ideas. Anyway those are the options I can think of, hard to say which is best.
  3. bigfitz52
    Aren't those thru-bolts like on the 550's? I gotta look at a parts diagram...
  4. kd5uzz
    kd5uzz Member
    Simple bolt that goes through (IIRC) the bracket, a rubber bushing, a steel bushing, another rubber bushing, into the headlight bucket bracket.
  5. asphaltgecko
    asphaltgecko Member
    ANOTHER ALTERNATIVE might be to have the machine shop drill-thead new
    holes next to the originals - and just move your brackets over a bit on the light assmby... IF THATS POSSIBLE.. NOT SURE.. but its a thought..
  6. mwhite74
    mwhite74 Member
    One of my bolts broke off like this as well this evening... Oak450 did you have any luck with this?
  7. 3784rider
    3784rider New Member
    New Zealand
    8O if you can see a bit of the bolt try welding a washer to the broken bit with a mig welder then use some visegrips but soak with some wd40 or what ever. :wink:
  8. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    It sounds like the headlight bracket bolts. Should have only been the handlebar clamp bolts.
  9. Robert
    Had the same thing happen to me. Saved myself the agony and grief and took it to the shop. $35 to drill it out and rethread the hole.
  10. mwhite74
    mwhite74 Member
    My neighbor and former Seca 400 owner managed to help me drill out and re-thread the bolt... gotta be careful with those old beasts don't we? needless to say i purchased a bottle of anti-seize compound :D Thanks for the advice guys...
  11. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Glad you got it fixed.
    I got tired of broken bolts, started using Aero Kroilon everything before trying to take it loose.
    KanoLabs still has a Google Special on Aero Kroil.
    2 - 13oz cans delivered to your door for $12.00.
