Morning start issues.
Discussion in 'XJ Technical Chat' started by Glen F., Jul 27, 2021.
  1. k-moe
    Honestly, I think that we've all been spoiled by too many years of fuel injected engines in our cars and trucks.
    Glen F. likes this.
  2. Glen F.
    Glen F. Active Member
    Winnipeg Manitoba Canada
    They were, but I'm going to check again tomorrow
  3. Glen F.
    Just checked the oil level because of all the troubles I was having with flooding, and I know I left a little space in the window, but it's gone. Gas in the oil again. Taking the carbs off again tomorrow.
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    This exactly - modern efi has the injectors right by the valves, and only one throttle. A mile apart from our bikes, not to mention a computer controlled idle air valve.
    In the meantime you need to rebuild your petcock ( unless you're leaving it on prime?), and check which carb is dribbling at the float valve - why not do this before removing them? A simple level check, repeated once or twice would no doubt tell you a lot.
    k-moe and Glen F. like this.
  5. Franz
    And you can extract codes on efi engines which help in identifying which part of the system is faulty. I am no expert but it is interesting how it works.
  6. Glen F.
    I did rebuild the petcock, and fixed the problem I had before where the thing with the holes in it had moved. I'll check that again as well. No it's not on prime unless someone was playing with it while I was at work.
  7. XJ550H
    if carbs are overflowing when running it will cause the issues. after you do what is needed to caebs, start and run some before putting on the airbox boots that way you will see if they leak
    Glen F. likes this.
  8. Glen F.
    Just drained the oil and checked the petcock. Oil had some gas in it. Petcock was fine.
    Could it have gone that badly out of sync? Everything was fine before.
  9. Polock
    the petcock stops the fuel when the bike is off, read that again.
    when the petcock stops the fuel, there isn't enough fuel left in the line to see any change in the oil window, even if the floats let it all drain out.
    whatever fuel went into the crankcase had to go past the petcock.
    ride it and pull the fuel line and route it to a can overnight
    Glen F. likes this.
  10. Glen F.
    I'll give it a try.
  11. Glen F.
    I have the tank off right now, and not a drop comes out. I didn't take it for a ride yet though.
  12. Polock
    i would think if you were to put two drops of gas in a new bottle of oil and shake it, it would smell like gas
    don't know about that one
    sync has nothing to do with it
  13. Polock
    i have a theory, you do the test.
    next time you park it, open the gas cap
    Glen F. likes this.
  14. Glen F.
    What will that show me?
  15. XJ550H
    maybe your vacuum line is sucking fuel,
    Glen F. likes this.
  16. Glen F.
    Can I do that with the tank off the bike?
  17. Polock
    well after a ride and you park it the gas and gas vapor is right over the hot engine.
    if the vent in the gas cap isn't working right maybe the gas expands and forces it's way through the petcock.
    it's only a theory but it's the only one i got :)
    XJ550H and Glen F. like this.
  18. Glen F.
    Well, I started it up, no problem. Raced to 3000 and turned back the idle screw to 2000. Let it go for a bit and slowly eased off the choke. Had it at half choke for a bit and it slowly died. Waiting for a bit to try again.
  19. Glen F.
    Slaps forehead with palm. I hardly had any gas in the tank. I'm an idiot. LOL Going for a ride and then test the gas cap.
  20. Glen F.
    Petcock was rebuilt with parts from Len
