Motor is locked!!!
Discussion in 'XJ Technical Chat' started by riide125, May 15, 2013.
  1. riide125
    riide125 Member
    Stanton ca (orange co)
    Want to know which motors will work for a straight swap on 82 650 maxim. Having hard time finding a motor or even a running bike local or even online. This is my only ride and need to get done ASAP. Idk if a different year would work or maybe a different size. Like I said I'm looking for plug and play. Maybe if I bought Another size complete bike I could use it on my bobber frame. Thx
  2. TIMEtoRIDE
    80 to 83 Maxim 650 is a drop-in
    82 Seca has a slight shifter location problem
    If you "go large" and get a 750 Seca or Maxim you need the ignition and carbs to run right. And more shifter problems.
    More complete info in "Information Overload" by Chacal.
    You'll never find a 900. 550's and 1100's are a different animal. Post your city !!
  3. mtnbikecrazy55
    Doesent Rick have a 900 sitting in a crate? :wink:
  4. mwhite74
    mwhite74 Member
    750 ignitor and carbs should be the same, aside from the obvious jetting in the carbs right? I just swapped carbs and TCI from my 650 to my 750 seca, and all I needed to do was swap the 3 main and idle jets and the needles (x4).
    Marcel
  5. riide125
    riide125 Member
    Finally found a decent motor. Should b here in about a week. Ill let u know how it goes
