Motorcycle Jack/Lift question
Discussion in 'XJ Technical Chat' started by clients, Jul 18, 2009.
  1. clients
    clients New Member
    Oakville, Ontario
    So I was sitting at home and my friend gave me a call telling me Canadian Tire had a motorcycle lift/jack on sale for 1/2 price ($60) Motorcycle Jack. Having a Canadian tire within spitting distance of my house, I popped over, brought it home and set it up.
    Didn't even cross my mind that the exaust goes right under the frame untill i went to try it out. So I was going to return it, but jumped on here just to see if there was anything I could do to salvage it and found this post:
    http://www.xjbikes.com/Forums/viewtopic/p=113173.html#113173
    I don't like the idea of jacking up the bike with the exaust holding the bike up or am I being to cautious and it should be fine.
  2. skeeter
    skeeter Member
    Iron Mountain, MI
    i wouldn't jack the bike up using the exhaust. maybe you can strategically place some wood blocks on the jack to get around the exhaust?
  3. kjohnson
    kjohnson Member
    Wetaskiwin, AB, Canada
    i use blocks of wood with mine, which happens to be from canadian tire as well
  4. clients
    clients New Member
    Oakville, Ontario
    Blocks of wood? Where do you have the wood butt up against the frame? I could see how i could get a piece of wood to lift up where the centre stand is attached, but near the front, I can't see anywhere which I could use to lift the bike besides from the exaust and the oil filter cover
  5. Pseudonym
    Pseudonym Member
    Return it lol. You're going to end up having to take off the exhaust every time you need to lift it, using wood blocks could be dangerous...
  6. clients
    clients New Member
    Oakville, Ontario
    I think I will probably end up doing that. I really liked the idea of having the lift, but i think it will be back to canadian tire :(.
    How do you guys put the bike up in order to say change the front brakes, or remove the forks?
  7. Motavator
    Motavator Member
    Stuart, FL
    Most would not agree but I use my motorcycle jack all the time with no Ill effects, Changed the head bearings, 2 New tires etc. Never had a problem with the exhaust pipes. I put the bike on the center stand and place the jack in front of the stand and jack it up.
  8. skeeter
    skeeter Member
    Iron Mountain, MI
    i have crash bars that i use to jack up one side and put wooden blocks under the other side.
  9. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I picked up a motorcycle lift table from Harbor Freight. It works great.
    MN
  10. clients
    clients New Member
    Oakville, Ontario
    How are you jacking up the bike? Right on the exausts?
  11. wamaxim
    wamaxim Active Member
    Vancouver, USA
    This is not my bike nor is it my lift but Harbor Freight's 1000 lb lift can be had for around $300. Wait til it goes on sale and then get a 20%off coupon.
    My bike weighs 854 lbs so I went with the fully pneumatic 1200 lb lift and paid around $400 for it.
    Once you have used one of these you will never be without one.
  12. baz666
    baz666 Member
    Washington, DC
    Are you talking about the the jack that has the bike sit on a platform on its center stand? It also has a section that pulls out so you can remove the front wheel? Is this the one you mean?
    The other type, with the two rubber-covered arms that go under the bike, is kind of useless. You have to remove the exhaust system and put the arms under the crankcase (carefully). Otherwise the whole weight of the bike is on the exhaust headers under the bike.
    I bought one of these useless type of jacks about a year ago for $109.99. Yesterday I saw them on sale for $59.99. Boy, do I feel like a sucker.
