Mounting Engine Guards / Rash Bars QUESTION
Discussion in 'XJ Technical Chat' started by pigmouse, Apr 5, 2006.
  1. pigmouse
    pigmouse Member
    Houston TX
    When mounting engine guards, do you simply pull the bolt out and poke it back in, or do you have to go get longer bolts to accomodate the added fraction of an inch?
    I was just gonna pull the bolt, slap 'em on, and put the bolt back in. Is that kosher?
  2. pigmouse
    pigmouse Member
    Houston TX
    Answering my own question....
    The top bolts need to be replaced with longer ones, but the bottom bolts are long enough to reuse
