My Christmas present That i could do without
Discussion in 'XJ Technical Chat' started by albear, Dec 25, 2009.
  1. albear
    albear Member
    <a href="http://maps.google.com/maps?q=-83.979259+
    HI all Merry xmas to you all!!
    my Christmas present that i could do without.
    Went to a xmas party on tuesday arvo & everything was fine,got up wednesday morning & went to start my old girl,turned key to on & noticed that i have no ingition light ,thought mmm just a fuse,down the driveway,went to beep the horn & no horn {mmmm},went to put the blinker on & nothing (mmmmmmmmmmmmm)
    Got to work & checked all the fuses & all r good.
    got home tonight & filped the headlight out ,tracked the wire loom & had a guess,got my circut tester out,earthed it & stuck it in the emd of the open plug& nothing,(mmmmmmmmmmmmmmmmmmmm)
    started to undo the switch block(l/h side)undid the front screw & what looks like could be a spacer???? was in at least 2 peices,cause family duties called & i could not find my stbby s/driver,so here iam know!!!
    Any ideas anyone help please
    cheers albear
  2. knuts2a
    knuts2a Member
    If you've got your test light out check the fuse box for power, both sides of the fuses. First thing i did on mine was to replace the fusebox for a "blade" type one.
  3. albear
    albear Member
    ok i have checked the fuse box & looking from the left side of bike the second fuse in line only has power coming, from the rear of the fuse box.
    how do i identify which fuse is for what????
    help please iam flying blind
    cheers albear
  4. markie
    markie Member
    Suffolk, England
    They should be marked - the largest will be the main fuse (30A?), followed by lights and then ignition. Is the identification inside the fuse box lid?
    Don't have a 900 so am only guessing but one fuse probably comes on with the ignition.
    Start at the battery and work outwards.
  5. wizard
    Looking from left side of bike
    MAIN 20 A
    HEADLIGHT 20 A
    SIGNAL 10 A
    IGNITION 10 A
  6. albear
    albear Member
    ok ,so went out to the shed & looed at the fuses really closely & cleaned them, & under the bright light it showed that it a small-hairline crack in the element,installed new fuse & away we go.
    thanks for your help.
    1 more question though, if the signal is on a different fuse to the ingition,why did i lose the ingition light???????
    cheeralbear
  7. wizard
    Except for the main fuse, the other 3 fuses are linked (brown)
  8. albear
    albear Member
    well there you go!!!!!!!!! :oops: :oops: :oops:
    cheers albear
