My first long ride =D
Discussion in 'XJ Technical Chat' started by Rage, Jun 9, 2009.
  1. Rage
    Rage Member
    I just made a nice long 500km (312mil) round trip journey on my XJ900. What a ride! the vibrations were intense at first, and my right hand numbed out; but for some reason, after about 45mins, the feeling came back, and the bike seemed to calm down.
    Before I left I ran my bike through the T-CLOCK check list, but now that I'm back... is there anything outside of the T-CLOCK scale that I should look for post ride?
    Here is the T-CLOCK check list copied from another forum for those of you not familiar.
    T-CLOCK Inspection Item What to check What to look for Check-off
    T - Tires and Wheels Front Rear
    Tires Condition Tread depth, wear, weathering, evenly seated, bulges, imbedded objects F R
    Air pressure Check when cold, adjust to load/speed F R
    Wheels Spokes Bent, broken, missing, tension,
    check at top of wheel: "ring"=ok--"thud"= loose spoke F R
    Cast Cracks, dents F R
    Rims Out of round/true - 5mm, spin wheel, index against stationary pointer F R
    Bearings Grab top and bottom of tire and flex: no freeplay (click) between hub and axle, no growl when spinning F R
    Seals Cracked, cut, or torn, excessive grease on outside, reddish-brown around outside F R
    C - Controls
    Levers Condition Broken, bent, cracked, mounts tight, ball ends on handlebar lever F R
    Pivots Lubricated
    Cables Condition Fraying, kinks, lubrication: ends and length
    Routing No interference or pulling at steering head, suspension, no sharp angles, wire looms on place.
    Hoses Condition Cuts, cracks, leaks, bulges, chafing, deterioration
    Throttle Operation Moves freely, snaps closed, no revving
    L - Lights and Electrical
    Battery Condition Terminals, clean and tight, electrolyte level, held down securely
    Vent tube Not kinked, routed properly, not plugged
    Lenses Condition Cracked, broken, securely mounted, exessive condensation
    Reflectors Condition Cracked, broken, securely mounted
    Wiring Condition Fraying, chafing, insulation
    Routing Pinched, no interference or pulling at steering head or suspension, wire looms and ties in place, connectors tight and clean
    Headlamp Condition Cracks, reflector, mounting and adjustment system
    Aim Height and right/left
    O - Oil and Fluids
    Levels Engine oil Check warm on centerstand, dipstick, sight glass
    Hypoid gear oil Transmission, rear driver, shaft
    Hydraulic Fluid Brakes, clutch, reservoir or sight glass
    Coolant Reservoir and/or coolant recovery tank - cool only
    Fuel Tank or guage
    Leaks Engine oil Gaskets, housings, seals
    Hypoid gear oil Gaskets, seals and breathers
    Hydraulic Fluid Hoses, master cylinders, calipers
    Coolant Radiator, hoses, tanks, fittings, pipes
    Fuel Lines, fuel caps, carbs
    C - Chassis
    Frame Condition Cracks at gussets, accessory mounts, look for paint lifting
    Steering-head bearing No detent or tight spots through full travel, raise front wheel, check for play by pulling/pushing forks
    Swingarm bushings / bearings Raise rear wheel, check for play by pulling/pushing swingarm
    Suspension Forks Smooth travel, equal air pressure/damping anti-drive settings F R
    Shock(s) Smooth travel, equal pre-load/air pressure/damping settings, linkage moves freely and is lubricated F R
    Chain or belt Tension Check at tightest point
    Lubrication Side plates when hot-DO NOT lubricate belts
    Sprockets Teeth not hooked, securely mounted
    Fasteners Threaded Tight, missing bolts, nuts
    Clips Broken, missing
    Cotter pins Broken, missing
    K - Kickstand
    Center-stand Condition Cracks, bent
    Retention Springs in place, tension to hold position
    Side-stand Condition Cracks, bent, (safety cut-out switch or pad if equipped)
  2. Ltdave
    Ltdave Member
    9 viewers and no comments so here ya go!
    congrats! thats quite a ride. ive never been that far. 86 from the mechanic to my house is the most ive done at a stretch...
    good job...
    i copied the T-CLOCK for myself...
  3. bigfitz52
    Dave! Is your 900 on the road?
  4. bill
    bill Active Member
    Raleigh, NC
    TCLOCK Should cover it - Origin is the Motorcycle Safety Foundation they teach it in the beginning and expert riders courses.
    They got to that part before I fell ;)
  5. MiCarl
    Almost. I refuse to finish it until he makes some T-shirts :lol:
  6. Ltdave
    Ltdave Member
    no.
    i talked with Carl saturday and hes going to seafoam the carbs since they seem to be a bit sticky since he cleaned them last fall. the rubbers (airbox side or intake side) are pretty well on their last leg and he doesnt think theyll survive another dismounting...
    ive got to get a title and plate for it and pay the insurance on it (not in that order...)
    the maxim is streetable except for the no-plate no-insurance ive got going on right now...
    ive gotten the 750 welded but its in commerce twp without a headlight, instrument cluster or any turn/brake lights or horns...
    yeah and i just went back to work and my father in law flies in from Denmark tomorrow. when it rains it pours...
    im on them though...
