my "parts bike" just arrived yesterday
Discussion in 'XJ Modifications' started by Jim Steele, Jul 14, 2016.
  1. Jim Steele
    Jim Steele New Member
    USA - Kansas
    I have an 81 750 (Seca) that's running and just took possession of an 82. The 82 is cosmetically better off than my other one (which I inherited). Both have some front seal leakage and the new arrival has no front brake pressure. Both have ugly crappy aftermarket (cheap) exhausts but the older one was re-jetted and fitted with pods. Whichever one prevails into my keeper, I'd like to put on a decent exhaust (stock if I could find it). any suggestions?
    First effort will be seeing if the new one will run - carbs and tank look almost too shiny, there was compression but there was no fuel or vacuum lines. Where should I begin...?
  2. dkavanagh
    Rochester, NY
  3. Jim Steele
    USA - Kansas
    Thanks - I've seen some of these already but it's a nice reminder of the location and availability of valuable info. Let's see if it will start this weekend...
    I would start by doing compression checks, checking calve clearances, and then deciding which engine is the best candidate for making a runner. I'd prefer the cosmetically better machine, but body parts can be swapped easier than engines. I would then take the second machine and go through the engine (replacing the alternator chain guide, and rebuilding the starter clutch) so it is ready for the eventuality that the runner needs engine work .
  5. Jim Steele
    USA - Kansas
    It runs... but only above 5000 Rs. I can start it with ether and the choke on all the way - so next stop is taking the carbs out. Compression was good, added new plugs... Also front brake cable was broken so I'll either need to find a new one or start pirating parts off of my other XJ.
  6. MiGhost
    MiGhost Well-Known Member
    The brake cable should be available from XJ4ever but plan on other parts also. You will want to rebuild the complete brake system.
    You know it runs now so start the process of making it safe and reliable again.
    ~Ghost
    Stumplifter likes this.
  7. amfmtxca
    amfmtxca Member
    God's Country Lubbock Texas
    Great idea I also have a complete parts bike
