Mysterious carb behavior
Discussion in 'XJ Technical Chat' started by joejr2, Nov 1, 2017.
  1. joejr2
    Santa Fe,NM
    I rebuilt the carbs on my "81" xj750 seca this summer. The bike starts right up with choke pulled
    all the the way. It warms up OK and idles faster after a while, but I can only ease the choke off about
    half way before it starts to stall. When I turn the idle knob nothing happens, but I can pick up the rpm's
    with the throttle grip.
    I did a thorough rebuild, disassembled soaked and cleaned all the parts in laquer thinner ( not the diaphrams ),
    blew out the passages with compressed air, new mixture screws springs and "0" rings, cleaned the choke parts
    with new "0" rings, polished the slides and cylinders and cleaned the accelerator needles, seats and jets. I cleaned out the pilot tubes in the float bowls and replaced the float needles and seats. It got new float bowl gaskets and I set the mix at 2.5 turns out. I set the float drop to specs and the wet test was close enough to
    leave things alone.
    For some background, the bike had pods on it, which I replaced with an airbox from a 650 seca. I looked up
    the jet sizes and they were within specs for an air box at this altitude (7,500'). standard carb manifolds fit the
    airbox just fine and the carbs installed easily ( new carb holder rubbers).
    When I took it for a ride, I left the choke half way and eased it off after a mile. the bike was balky but didn't stall.
    When I stopped at a light the revs stayed high without any throttle. I got back home right away.
    Any tips ? too lean, too rich, wrong jets, need throttle shaft seals ? Wrong accerator cable etc. ?
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Once it is fully warm, does it idle and respond to throttle well without stalling with no choke?
  3. XJ550H
    to set idle properly you need to go for a ride. about 10 miles should do it. pull over somewhere safe and adjust idle to 1050 rpm
    look to see that the idle knob is moving throttle shafts.
    did you bench sync carbs?
    stock paper filter or one of those problem laden K&N filters use a stock paper filter.
    here are the jets you should use unless you are in Canada. Canadain jets Pilot FUEL Jet Size: #43 Pilot AIR Jet Size: #195 Main jet NEEDLE ID: #Y-14
    XJ750 Models:
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 15R00 (Maxim, Midnight Maxim)
    Carb Model ID: 5G200 (Seca)
    Main FUEL Jet Size: #120
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #80
    Pilot AIR Jet Size: #225
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-13
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
    air jets go in like this which is the correct way Haynes manual shows them in the incorrect position
    sounds like your pilot jets are still clogged if it will not run off of choke. they run the bike until 2000rpm
  4. XJ550H
    mixture screw assembly put spring then washer then o ring on mix screw. 2-1/2 turns out from soft seat. where did you get the orings for mixture screws?
    with your reves high try backing out on the idle knob of course the choke must be off or rpms will climb to about 4k rpm
    did you change the throttle shaft seals? did you soak carb bodies?
  5. joejr2
    Santa Fe,NM
    So, senior dog face do you see any problem with using an airbox from an xj650 seca in an xj750 seca ? I will most likely pull the carbs
    and check the jet sizes against your list, thanks. But would those jets be too rich for Santa Fe's altitude of 7,500 ft. ? I was also wondering
    if my throttle cable is the proper length ? Do you know how long the throttle cable on an xj750 seca should be ?
  6. joejr2
    Santa Fe,NM
    I did install the mixture screws, spring, washer "0" ring in the proper order but I didn't install new throttle shaft seals ( I will do that) as well as a better wet set job.
  7. XJ550H
    all i can say about the air box is if you put a 750 motor in a 650 frame you use the 650 airbox so it should be good.
    throttle cable has an adjuster at grip should be a little slack at carbs not tight and cable should be lubed or it can stick and properly routed
    from
    XJ PARTS CATALOG, SECTION M: CONTROL CABLE AND HAND LEVERS
    HCP2696 OEM original THROTTLE CABLE, with black curved plastic tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all 1981-83 XJ750 Seca and XJ750 Euro models. Wire length = 41".
    HCP2655 Aftermarket THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all 1981-83 XJ750 Seca and XJ750 Euro models. Wire length = 40-1/2".
  8. XJ550H
    bad throttle shaft seals will cause a high idle if you soaked the bodies you need new seals you can use 2 #11 buna orings as throttle shaft seals in each location. I go with new seals to remove doubt.
    improper wet set will also cause idle problems
    how to with specs
    Setting the fuel levels
    low levels will starve motor of fuel and high will flood engine run rich
    I do suggest you check cable and if idle knob is resting on throttle shaft first
    desmotom likes this.
  9. XJ550H
    as far as altitude goes I live in the valleys of mountains and when I ride in the higher altitudes my idle rpms go up 100 rpms and corrects when i am back in the valleys 600 feet above sea level.
  10. Jetfixer
    ^^^^+1 what XJ550H says ...of you soaked carbs without removing shaft seals...you will have vacuum leaks after 30 years they loose the sealing ability ..this is one of the problems from the sound of your post. Do a full tear down spate carb bodies fro the rack ,remove butterfly plate and pull the shaft this is the ONLY way to replace shaft seals there are one on each side of the carb body .
  11. joejr2
    Santa Fe,NM
    Yes indeed it looks like another carb. party. This is the fourth set I've done and it's getting easier each time.
    as soon as I figure what's killing my Atari and blowing the signal/horn breaker, the carbs will be next. by the
    way, I've got a really good system for removing and reinstalling carbs. If I can figure out how to post pics from my
    picasa library I'll document the process.
  12. Jetfixer
    I've said it before but will say it again ...do not take short cuts doing the carbs...spray carb cleaner will not get in to all the passages...and do it right the first time and save yourself the missery of doing asecond or third or fourth time :(
  13. hogfiddles
    Where did you get your jets from?
  14. joejr2
    Santa Fe,NM
    I cleaned and re-used the jets that were already in the carbs. When I purchased the bike it had pods on it. I switched back to an airbox
    but didn't change the jets. What would be the proper size main and pilot fuel jets and main and pilot air jets ? I am at 7,500' in
    SantaFe, NM. I didn't mean I pulled this set of carbs four times, The xj750R that I'm working on presently is the 4th xj bike
    I have rebuilt from junk over the last three years.
  15. XJ550H
    carb specs
    http://xjbikes.wikidot.com/carb-specs
    Carb Series: HSC32
    numbers are on the jets but that does not mean the po did not drill them out to tune for pods
    Lightcs1776 likes this.
  16. hogfiddles
    case in point--- I did a rack for another person a few months ago.....one of the 36's was drilled out to about a 52
    Lightcs1776 and Toomanybikes like this.
  17. joejr2
    Santa Fe,NM
    thank you guys, super helpfull
  18. chacal
    Bigger is always better, right? :)
  19. XJ550H
    while we are on the subject how are the drill bits sized. obviously not 52mm would a 52 jet be .52mm or .052mm? I remember a thread where it was mentioned.
    also Hatachi carb jets are measured in mm but mikuni jets are measured in fuel flow if i recall correctly from that thread.
  20. chacal
    Also, if you’ve ever wondered what the numbers on your jets refer to:
    - on Hitachi fuel jets, the numbers refer to the actual physical size of the passage hole expressed in millimeters, i.e. a #114 fuel jets is 1.14mm in diameter, a #42 fuel jet is 0.42mm in diameter, etc.
    - on Mikuni fuel jets, the numbers are a measurement of the volume (cc’s of gasoline) that will flow thru the jet when poured in from a height of 50cm.
    - we do not know what air jet numbers refer to…….although we suspect it is a volume of air that can pass through the jet at some level of vacuum. Anyone who has insight into this issue please let us know more!
    XJ550H likes this.
  21. joejr2
    Santa Fe,NM
    So, in purchasing jets, one would have to be sure that they are for hitachi rather than mikuni carbs, or the numbers would be totally misleading. correct ?
  22. XJ550H
    mikuni the pilot jet is completly different style
  23. XJ550H
  24. k-moe
    And they won't fit, as mentioned above.
  25. chacal
    But if I recall correctly, the main fuel jets will interchange, the head sizes are different between Mikuni and Hitachi carbs, but the main fuel jets will physically interchange.
