Mysterious Spring
Discussion in 'XJ Technical Chat' started by msgoodwrench, Jun 16, 2017.
  1. msgoodwrench
    msgoodwrench New Member
    Ohio, USA
    Hi all! I have an 82 XJ550J and I notice that there is a small broken tensioning spring that sits on the push lever shaft, just under the push lever. It appears that it might tension against the push lever? I have had no problems, but would like to replace it if it needs to be replaced. Obviously it is broken, but I am not sure how important it is? How hard to replace? Looks like you would be messing with a spline lining up job there on the push lever parts. Not sure how it mounts exactly either; where the other end of the spring attaches. I cannot seem to find this part in the parts list anywhere, and am not sure what to call it. Should I just ask Chacal or someone have some ideas? Thanks for your help.
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Picture?
  3. msgoodwrench
    Ohio, USA
    sorry, I copied and pasted a pic, but it is not in the post, not sure why??? will keep trying I guess.
  4. msgoodwrench
    Ohio, USA
  5. msgoodwrench
    Ohio, USA
    looks like the uploaded picture went thru, okay?
  6. chacal
    That the clutch pivot shaft return spring, you DO want to replace it. The top of the shaft and the arm have a locating mark/notch in them to guide you in re-assembly (but, use a sharpie, etc. to draw an alignment mark across the two pieces before dis-assembly. Not hard to replace, it will become obvious where the spring retention arm fits once you have a new spring!
    http://xjbikes.com/forums/threads/reassembly-of-clutch-cover-82-xj750j-maxim.44555/
    http://xjbikes.com/forums/threads/clutch-lever-offers-little-resistance-xj550k.25394/
    http://www.xjbikes.com/forums/threads/bike-not-staring-and-shifting-gears.72992/#post-479385
    HCP3208 OEM clutch pressure plate pivot axle shaft RETURN SPRING. Fits all XJ550, 1984-85 FJ600, XJ650, XJ700, XJ750, and XJ900 models. Each:
  7. hogfiddles
    Clutch return spring. Len at: info@xj4ever.com will have it
  8. hogfiddles
    Oops, replied before reading the rest of the thread. I see he's already on it.......
  9. msgoodwrench
    Ohio, USA
    well once again, many thanks to Chacal! Appreciate it, I will get on ordering that.
