Name of part on a Maxim
Discussion in 'Hangout Lounge' started by raskal, Oct 10, 2018.
  1. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    Can't figure out what to call this part, so I can search to find a good way to restore/paint it. It's the part between the front signal lights (see attached picture)
    also, have you ever seen a Maxim that comes with a spare horn?
  2. Andyam5
    Andyam5 Member
    Luton, UK
    Fork emblem? Front badge?
    Strip it with bleach, rub it down and spray paint
    Jetfixer and raskal like this.
  3. Toomanybikes
    Tsawwassen bc
    Horn from alarm system?
  4. hogfiddles
    Yup, fork emblem
  5. raskal
    not connected to anything. Just is sitting there
  6. raskal
    thanks guys
  7. XJ550H
    its for the passenger
  8. hogfiddles
    Toomanybikes likes this.
  9. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I think its serving its intended purpose right now. Making everyone go what the??? Why would someone do that???
  10. Robzzzr
    Robzzzr New Member
    UK, cumbria
    On the fork emblem, used budget paint stripper on mine with an old tooth brush, then primed and sprayed it. Note The Stripper is not powerful enough to melt the plastic
  11. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    That horn under the seat is actually a factory mod. It goes off if a fat chick sits on the bike so you don't take her home when you're drunk! ;) ;)
    Jetfixer and Toomanybikes like this.
  12. raskal
    I painted the emblem. I just sanded the old paint and used a Rust-oleum that said it was good for plastic
    Jetfixer and Stumplifter like this.
  13. Maxim-X
    That's quite a transformation, nice work.
  14. Robzzzr
    Robzzzr New Member
    UK, cumbria
    Looks good , suggest a coat of clear laquer on top easier to clean the bugs off!!
  15. raskal
    yeah I thought of that too. I'm doing a test piece in case the clear coat has an adverse reaction with the paint
  16. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Looks good. Plus 2 on the clear coat.
    I'm guessing if you use clear coat from the same maker and line of paints it won't react with the original paint.
  17. Maxim-X
    Spray a test piece with the paint if you have any left and then try the clear. If it works, YAY!!!!!!! if it doesn't AH CRAPPPPP, but it was only a test piece any way YAYYYYYY!
  18. raskal
    Wow! The peer pressure on this site is unreal!
    fine. I did a clear coat
    In normal fashion for me, I sprayed it too thick and it ran, so had to sand & re-paint part of it.
    Oh well, good enough from a distance
  19. Maxim-X
    No pressure...shoulda went with the test piece. Just kidding.
    raskal likes this.
  20. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    The second "Horn of a dilemma"
    Cheers, 50gary
