nearly there
Discussion in 'XJ Modifications' started by rubberlips, Jun 14, 2008.
  1. rubberlips
    rubberlips New Member
    ireland
    hi all,well im nearly finished triking the 1100 maxim.got some painting left to do and connect up the brakes,it should be ready for road again soon.
  2. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Dude that's pretty cool! Some more pics would be nice!
  3. Stamplicker
    Stamplicker Member
    London Ontario
    Yes More Pics!!!! Damn!
  4. Ease
    Ease Member
    NL, Canada
    Whaaaaaaaaaaaaaaaaat!?
    Sick frame!
    Dirtbike front wheel??
  5. rubberlips
    ireland
    hi and thanks ,ill put up some more pics.
  6. rubberlips
    ireland
    got a bit of work to do to the sissy bar yet.
  7. rubberlips
    ireland
    another
  8. rubberlips
    ireland
    i still have to finish off the front fender.the frontend is off a ktm,got to change the tire for a road one.
  9. KAOS
    KAOS Member
    Newport, Maine
    Damn Dude!!! Rock on with that "Trike"!!! :twisted:
  10. MidniteMax
    MidniteMax Member
    Liberty SC
    Cool ride!
    Kind of hard to tell from the photos how the driveshaft connects to the differential.
    Got any close up photos of that area?
  11. rubberlips
    ireland
    hi,i will take a picture of that later.im painting the shaft so its not on in the picture.i cut the shaft in half off the car axle,& the bike shaft,put a bearing the right size over the section from the bike and slid it into the car shaft.drilled a metal plate and welded it on the end.turnes perfect no shake at all.get you a pic later.
  12. MidniteMax
    MidniteMax Member
    Liberty SC
    That machine has some really nice lines. Looks like you set it up right.
    Rock on!
  13. rubberlips
    ireland
    hi the front end is off a ktm,need to change the tire for a road one,but my wife would rather buy food for my five kid's than let me buy the tire so ill have to wait awhile i guess
  14. rubberlips
    ireland
    hi midnitemax,hope this picture is allright.
      File size:
      117.6 KB
      3,035
  15. Stinky
    Stinky Member
    Flagstaff, Arizona
    Looks fun. How does it ride?
  16. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    Lookes Mad Max with that front tire. Where did the diff come from?
    Thats a rockin ride. Kudos
    The Buff
  17. rubberlips
    ireland
    hi,the differential and axle are off a robin reliant car.i cut down the axle and half shaft to make it narrower ,and line up the drive shaft.
  18. Ease
    Ease Member
    NL, Canada
    Not a bad idea for the inverted forks.
    Did it bolt right on or was there a bit of fab work?
  19. seca750
    seca750 Member
    New York
    Love the Bike, sorry Trike!
    I was wondering how the XJ would look with inverted forks! Very Nice! You got the front off a KTM, what year any pic on the assembly?
  20. rubberlips
    ireland
    hi,no it dident bolt right on, the center neck bar on the ktm was bigger.i had to remove that & take the center neck off the origional triple trees from the xj not easy it was welded ,but it went in the ktm triple trees good.then i had to make brackets to take the gauges ,ignition switch,and had to make a front fender because the ktm forks carry the fender right under the triple trees.but there good strong forks & about 3 1/2" longer than the xj.i cut the neck too and increased the angle a little bit.thanks
