NEED A ELECTRICAL HELP!!!
Discussion in 'XJ Technical Chat' started by Alex mathieu, Sep 5, 2015.
  1. Alex mathieu
    Alex mathieu Member
    griffin ga
    So originally the break light would stay on constantly. Checked the switches. Rear break switch worked. Front tested good. 12 volts constantly still to break light. DID NOT CHANGE ANY ELECTRICAL COMPONENTS OR CHANGE THE WAY ANY COMPONENTS OR WIRES HOOK UP! I pulled headlight off to get to front break light wiring. And took of tachs to better reach and see wires. DID NOT UNPLUG TACH! AT ALL! once everything was back together I started the bike but the rpm TACH wasn't running... pulled front break...the rpm tach starts working..ONLY WHEN FRONT BREAK IS PULLED! I don't understand what has happened but I don't know what to do now... PLEASE NEED HELP IMMEDIATELY!!! LY
  2. Alex mathieu
    Alex mathieu Member
    griffin ga
    Have looked and looked for wiring for this bike with Absolutely no luck. ..
  3. Alex mathieu
    Alex mathieu Member
    griffin ga
    headlight not turning on blinkers don't work blinkers running lights work, but blinkers don't
  4. Alex mathieu
    Alex mathieu Member
    griffin ga
    Fuel light has never worked. When holding front break, the rpm gauges works and also when holding the break if you turn in either blinker, the fuel light Will blink as if it was the blinkers. Horn doesn't work whatsoever. I have no idea where to even start. It's like everything is working the wrong function...
  5. Alex mathieu
    Alex mathieu Member
    griffin ga
    Will upload video soon. If you push down the rear break it will also have the same effect as the front break. If you try to use the horn while holding the break, it's like it all loses power...
  6. XJ550H
    posted a link in your other thread for repair manual down load free
  7. Alex mathieu
    Alex mathieu Member
    griffin ga
    Thank you
  8. Alex mathieu
    Alex mathieu Member
    griffin ga
    Here is a video of what it is doing!
  9. XJ550H
    if this problem showed up after you remover the headlight, I would go back and see if you pinched a wire when you reinstalled the head light and tach
  10. Alex mathieu
    Alex mathieu Member
    griffin ga
    Pinched a wire? I understand what your saying, but i dont even know where to start... what wire could make such a compound problem???
  11. Alex mathieu
    Alex mathieu Member
    griffin ga
    Losing power in brown wire somewhere
  12. hogfiddles
    Almost sounds like you have some similar-looking wires or connectors mismatched....
  13. Polock
    what happens when you pull the clutch in? does this happen in all gears? might need to set the valves
  14. Alex mathieu
    Alex mathieu Member
    griffin ga
    No, I have a power probe that I can add or take power from any wire. If I add power to the brown wire, everything works... etc, the blinkers, horn brake light... it also tells me what kind of voltage I'm getting. No power to this wire period. From the look of this diagram, it runs through just about everything...
  15. Alex mathieu
    Alex mathieu Member
    griffin ga
    Also I've not changed the wiring in any way form or fashion... it is all the same as it was before the problem started. I've lost all power to this brown wire. I'll take a pic of the wiring diagram.
  16. Alex mathieu
    Alex mathieu Member
    griffin ga
  17. Alex mathieu
    Alex mathieu Member
    griffin ga
  18. Polock
    i hate when that happens
  19. k-moe
    You've got an intermittant fault. Start at one end of the wiring and proceed to the other. Yes, the sucky part of electrical repair.
  20. Alex mathieu
    Alex mathieu Member
    griffin ga
    That's exactly what I've been doing for hours on end. .BUT I found it! Was a 15 amp fuse behind the indicator lights that was blown. . THANK YOU ALL for the help and especially the WIRING DIAGRAM to my bike. Would have took alot longer to find. :) Love this site!
  21. XJ550H
    pinched in the headlight ring.
    also when you squeze the brake lever you make a connection to ground. the voltage is at the bulb and the squezing of the brake completes the circuit to ground with the bulb filliment acting as a resistor
    the brown wire comes from the ignition switch and brings voltage to the rest of the fuses, it is supplied from main fuse to ignition switch. turn key on connects to brown wire.
